Injectors needed for 600hp on 95 Octane
Hi all
I'm at the stage where I need to upgrade my ID1000s to support more boost.
Currently I have a fully built engine with a GTX3576R bolted on to a Sheepey with a 340 in tank 340 making 485 @ 17psi.
I want to make 600+ on 98 octane fuel (high octane pump fuel in the UK, E85 isn't easily available).
For the next tune I have installed 2x Bosch 044s into an integrated engineering fuel surge tank (fed from the in tank 340) on to a -6 tapped dual feed OEM fuel rail.
Now I need to think about injectors.. I think I will max out the ID1000s looking for 600 so looking for some 1300cc injectors..
Does anyone have any real life feedback with the DeatschWerks 1300 injectors? The spray pattern looks good on paper and they are considerably cheaper that the ID13000 but there is normally a reason for this..
Any feedback would be appreciated. Or any other injector type to recommend other than the $900 ID1300s!
Unless you are planning for more down the line(Dual Bosch 044's seems to insinuate it) the 1000's should work. You could just bump the fuel pressure up to 50 for a little extra room(7% more fuel). Normally I suggest getting a larger injector, but you already have the 1000's, and I think they would likely work without bumping up the pressure anyway. I've made 600+whp on 1000's but every dyno is different so I'm sure others could have maxxed out before that.
I'm running the dual because I got them cheap off a friend and I like the idea of have a secondary "redundancy" pump. I won't have them both running all the time, probably have a switch so the 2nd is activated under boost. Seen guys have reached the limits of a single 044 @ close to 600 before so also figure since I have 2 might as well have that extra capacity. Luckily they will be nearly all submerged so shouldn't be as noisy as in line.
My tuner thinks I will need to upgrade to larger than the ID1000s to comfortably make 600hp let alone 600whp
However we haven't discussed raising base fuel pressure.. Is there any cons to doing this?I have no problem with this but another $900 is a bit much. I guess I'm looking for someone to report that they have had good experiences with the deatschwerks injectors 1300cc injectors as they are more attractively priced. Maybe not worth risking my built engine on tho..
KraftWerks
May 14, 2013 01:48 PM
