Injectors still useable?
Old May 11, 2010 | 07:30 PM
Ian300D's Avatar
Ya your good, just make sure nothing else will break off. And start saving to replace them as your next mod for sure. Hell I've seen RC 750's go for as low as $150 a set.
Old May 11, 2010 | 07:37 PM
TRBOKEV's Avatar
I wouldn't put those in my motor, they look like sh*t and who knows how the flow is if they look that bad on the outside.
I'd keep the car parked till I got a new set.
Old May 11, 2010 | 07:41 PM
RedLineS2k10's Avatar
Originally Posted by Spoolin,May 11 2010, 06:40 PM
I dont think there is a small oring that goes on the spray nozzle tip of the injector. It wouldnt seal on anything in the intake manifold. Only one or two large orings are used on the mid area to seal.
That crap thats broken on the end I dont think will hurt anything in the way they work. The spray pattern is internal. If it were me, I'd just break the rest of it off and do the same on all of them so nothing will come off and go into the engine.
I have the RC 750's..Im not a genius, but breaking pieces off the injectors and trying to reuse them with o-rings...in my opinion is a bit ridiculous. Just replace them. Dont cheap out on your motor
Old May 11, 2010 | 07:53 PM
AFs2k's Avatar
Yeah, I would only use them for a little while broken like that. They look rough. (been to hell and back) As soon as possible I'd change them out though.
Old May 11, 2010 | 07:54 PM
Spoolin's Avatar
^^I didnt say to reuse them with orings on the tips, I said that the tips of the injectors dont use an oring with our intake manifold. The only orings used are at the mid section of the injector, the large orings and 2 are supposed to be used.
As for the plastic piece on the tip, it can be broken off the rest of the way without hurting any other parts of the injector housing. The RC1000's dont even have this plastic covering on them so I dont see any problem with removing it. All you have to do is take a straight edge razor and score all the way around the plastic at the furthest lip point that the plastic connects to the body of the injector and break the tip part off.
rsx, can you show a picture of one of your injectors that doesnt have the plastic broken? Kind of like the last picture you posted but pointing a little more at the front of the tip so we can see how it looks with the full plastic in tact.
Old May 12, 2010 | 03:40 AM
trbod00's Avatar
i have brandnew rc 750s that were on my car for 2 days and there still shiny! id prob sell them. if your interested pm an offer
Old May 12, 2010 | 10:40 AM
rsxiness03's Avatar
theres some mroe pics u asked
for
Old May 12, 2010 | 01:10 PM
Spoolin's Avatar
Thanks. Now looking at how that plastic tip is on the injector, its possible that the broken piece and removing it from the other injectors may cause a bad spray pattern but I'm not too sure. I wasnt aware that the plastic tips went that far into the spray area. You may want to go ahead and contact RC and show them the pictures and see what they say. They may even take these in for a trade on some new ones and give you a discount if they say they shouldnt be used.
So-Lo
Jan 24, 2011 08:52 AM
