Inline Pro Engine #3 compression/leakdown results
Old Jul 22, 2020 | 06:32 PM
F1TwoThousand's Avatar
Here was my issue, bent intake valves showing 10% leakdown
Old Jul 23, 2020 | 05:21 AM
Dizings2k's Avatar
Originally Posted by RAIN H8R
You will ALWAY have air coming out of the dip stick, its normal. You need to verify that high leak down % value isn't from any of the valves or a head gasket leak, again the head gasket likely isn't leaking.
My ILP Stage 2.5x head was pretty good. The valves sealed with the springs removed. I do vacuum tested on the intake and exhaust ports to test leakdown before I assemble an engine.
Good thoughts. It's been raining hard here but this weekend I'll have a chance to drive the car warm and do this test again. Now that you mention it, I recall the amount of air coming out of the dipstick on Cyl 2/3 being about the same as the "good" cylinders...
Also, during the very first engine rebuild, all of the valve seats were cut out and replaced entirely in my head. Some of them were sunk from botched previous machine work, so I had them just replace them all. Maybe I do have some valves on 2/3 that aren't sealing properly?
Ugh.. the thought of removing the IM with the motor still in the car makes me sad. ha. I should be able to hear something by listening through the TB I hope.
In other news, I replaced both O rings on the dipstick now and I had no idea how worn my old ones were. It's a legitimate pull it takes now to remove the dipstick out. If it pops out now I have some serious issues going on.
Old Jul 23, 2020 | 11:17 AM
Dizings2k's Avatar
Originally Posted by Charper732
You know what the ptw and ring gaps are? If the O-rings are good on the dipstick and you have a couple -10s to the catchcan, it blowing the dipstick up is not good. 20% is a good bit. for reference I'm running .004" ptw and .021" and .028" ring gaps. My leakdown after a short break-in is less than 10% @ 100psi
Here's exactly what's in my motor: Custom FRM 87.50mm bore 10.6:1 compression Turbo Forged Flat Top CP pistons with rings and wrist pins
Inline Pro HD H beam connecting rod set with 3/8" ARP2000 bolts
Stock F22C crankshaft
Piston to wall clearance .003"
1st ring gap .022"
2nd ring gap .026
The lower compression pistons explain the lower compression numbers. They didn't tell me they changed the type of piston to a lower compression one on this build until I just asked for the specs on the motor.
Old Jul 23, 2020 | 03:58 PM
Charper732's Avatar
Wait...a FRM bore? I thought this was a sleeved block? 003" is a lot for a FRM cylinder, but is a bit tight for a sleeved one. I dont trust hone/bored FRM cylinders especially with pistons that need coatings added after the fact to make them compatible.
Old Jul 23, 2020 | 05:06 PM
Chuck S's Avatar
The bore sleeve is indeed FRM (not the block *). Which is why it's impossible to rebore the engine.
-- Chuck
* don't worry we knew what you meant.
Old Jul 24, 2020 | 03:58 AM
Dizings2k's Avatar
No, this is not a sleeved block.
Old Jul 24, 2020 | 08:23 PM
Spoolin's Avatar
Hahahahaha........ If that dipstick comes out now, it'll come out like a mad cat that had it's asshole hit with sandpaper and rubbing alcohol poured on it.
Old Jul 24, 2020 | 10:43 PM
RAIN H8R's Avatar
remove the intake pipe on the throttle body. Open the throttle plate to hear air out of the intake. Put your head by the exhaust tip to hear exhaust valves.
Old Jul 25, 2020 | 02:14 AM
Charper732's Avatar
-- Chuck
Gotta love experts with zero experience who try to correct people....anyway.
eh, I know a few have had good luck with bored FRM cylinders, but I have yet to see one personally. I've seen a couple of their FRM blocks that have been bored out and rebuilt by them and neither of them lasted more than a year and both were N/A builds. The last one was a street/track car. It was filling the catch can and spitting the dipstick in less than a year.
The only thing I could recommend you try is to get the motor good and hot and try the leakdown again. verify it is the rings and not the valves. .003" is a lot of clearance considering you are working with a cylinder that has an aluminum base.
Old Jul 25, 2020 | 07:12 PM
Dizings2k's Avatar
Well, some good news for once.. albeit minor. I did some WOT pulls today and the dip stick stayed in place completely with the new rings.. and it was oriented normally, not backwards as some have tried.
I’ll try a leakdown test tomorrow and I’ll make sure the motor is as hot as possible. The last leakdown I did was after the car was driven hard but it did sit for about 45 mins before I did the test, so it would’ve cooled a little.
