An Inline Pro and LoveFab Connection
Old May 14, 2015 | 06:34 AM
  #91
staylor725's Avatar
Wow looks really good, nice work! What do you think its going to run?
Old May 14, 2015 | 09:43 AM
  #92
squirrels2k's Avatar
Thanks guys. Im anxious to see how the th350 works out as well. Ill definitely let yall know how it holds up to the constant abuse. Hopefully I can get it sown in the 9s. Not looking for anything faster than that truthfully. I still have to weld up a full cage, get a hardtop and some skinnies for the front.
Old Jul 8, 2015 | 02:43 PM
  #93
Still trying to finish up a little wiring before I take the car to d3 performance for a tune, but here is the latest. Called up summit racing and ordered some 15x9.275 rt-s rears and some 15x3.5 alumastar fronts. Then shaved the calipers to make them fit without spacers. Tucks nicely.
Old Jul 9, 2015 | 12:54 AM
  #94
JJAUTOWERKS's Avatar
Former Sponsor
Looking good!!
Old Mar 26, 2016 | 08:06 PM
  #95
herecomesboost's Avatar
Update? How's the car running? How much clearancing of the trans tunnel was required to fit the TH350? Hope all is well.
Old Mar 27, 2016 | 08:08 AM
  #96
Car is running well. Havent had the opportunity to see its full potential yet due to work and moving but its holding up great so far. Only spot i had to cut was a hole in the passenger floor board to allow extra clearance for the tranny cooler lines. It is a tight fit but i havent had any rubbing thus far.
Old Mar 27, 2016 | 08:29 AM
  #97
Awesome. I appreciate the update! Likely going this route (or TH400). Do you know if D3 are still manufacturing the adapter plates?
Old Mar 27, 2016 | 09:16 AM
  #98
I dont think d3 is having it made anymore. Huy at inline racing in Houston told me that bmc machine shop made them for d3 so that may be one direction to look. Im very surprised at how smooth this tranny setup is for regular driving
Old Mar 29, 2016 | 02:39 PM
  #99
sohc_mshue's Avatar
Nice. What kind of converter stall are you using with the trans? How high can you stall it up on the trans brake and how much slip are you getting on the top end?
Old Mar 29, 2016 | 06:13 PM
  #100
6200 stall in a 7" Hughes converter. Havent been able to see how the top end is yet. Have to change my rear end gears. Im running out of gear way before top end. As soon as i have some complete results i will let yall know.
