inline pro stage 1
Hi guys. im just about ready to fork out for the stage 1 inline pro kit. from what ive found it seems to be the way to go compared to the greddy kit.
just a few quick questions though.
a) is it a direct bolt in with rhd drive s2000s?
b) is all thats required to complete the kit as a bolt on the injectors and AEM?
cheers
John
cheers
John
Do some searching, there is a ton of info on inlines kit. Over all the kit is fairly straight forward to install. A little welding is needed and the overflow tank needs to be relocated. But again, search you'll find a lot of info.
There are modifications that are needed for the intercooler piping to fit (trimming of headlinght supports). If you go any turbo with an "E" cover or bigger, you will have to notch the frame. I believe the precision 5965B is the largest you can go without notching. Not sure of the Garrett turbos.
boostovereverything
Mar 2, 2012 02:00 PM
Iceman1
Feb 15, 2006 08:49 PM
slimjim8201
Oct 6, 2005 06:55 AM
