Inline pro stage 1 intercooler pipes
I searched but it seems like everyone who has installed the inline pro stage 1 kit has removed the air pump. I seem to be having trouble with trying to install the intercooler pipe on the driver's side with the air pump in the way? Is it possible or must I remove the air pump?
Just the hassle with removing it and then having to reinstall it for smog/inspection in California. Also, I keep misplacing parts when I upgrade or modify things.
Just trying to see if it's a must remove.
you won't for that, but then you won't have to reinstall the air pump and remove charge pipes/etc
would make it a lot easier to just throw stock ecu and whatever else back in and not worry about the air pump anymore
just a suggestion
just a suggestion
