Inline pro stage 1 intercooler pipes
Old Sep 3, 2011 | 09:04 PM
gnehc1's Avatar
Default Inline pro stage 1 intercooler pipes
I searched but it seems like everyone who has installed the inline pro stage 1 kit has removed the air pump. I seem to be having trouble with trying to install the intercooler pipe on the driver's side with the air pump in the way? Is it possible or must I remove the air pump?
Old Sep 3, 2011 | 09:32 PM
DFWs2k's Avatar
Why wouldnt you remove the air pump?
Sent using free Tapatalk - Android ftw
Old Sep 3, 2011 | 09:39 PM
gnehc1's Avatar
Just the hassle with removing it and then having to reinstall it for smog/inspection in California. Also, I keep misplacing parts when I upgrade or modify things. Just trying to see if it's a must remove.
Old Sep 4, 2011 | 06:27 AM
DFWs2k's Avatar
I have an air pump bypass kit for sale that will let you remove and still pass, then you will for sure have room and will save weight.
Old Sep 4, 2011 | 06:40 AM
gnehc1's Avatar
I'll be using the AEM EMS...I thought that I won't need an air pump bypass kit??
Old Sep 4, 2011 | 07:40 AM
DFWs2k's Avatar
you won't for that, but then you won't have to reinstall the air pump and remove charge pipes/etc
would make it a lot easier to just throw stock ecu and whatever else back in and not worry about the air pump anymore
just a suggestion
Old Aug 16, 2013 | 03:57 PM
jimbojoooones's Avatar
How much for the air pump bypass kit? I'm located at West Chester, PA 19380
lotushonda
Ηλεκτρικά Θέματα
Mar 19, 2015 04:04 AM
rsxiness03
May 11, 2010 10:45 AM
gravitykills
Aug 28, 2008 06:34 PM
gravitykills
Aug 26, 2008 02:48 PM
