Inline Pro Stage 1 vs Full-Blown Turbo Kit
I was on an inline pro stage 1 set up with a 6265 jb turbo. I could only make 360 max before I seen knock. I was at 16 psi and was at 103% duty cycle on my rc 750cc Injectors.
Im now on a sidewinder set up with the same turbo, e85 and fc2150cc Injectors making 500 HP on 15 psi.
You will make 100hp more on a sidewinder at the same psi as a log. Do not go log!!! The back pressure from that log is really bad and you will have to buy a greedy spec b turbo controller to control the boost spike that log will give you. The inline pro log is set up to run a 38mm wastgate... It's to small for the flow our cars put out.
Do it right the 1st time and buy a sidewinder!!!!!
Inline pro has some great kits and they do hold up but if your going inline ... Just get there stage 2 kit.
Thanks for all the input guys. I also plan on using ID 1000cc Injectors and a 255 Walbro fuel pump. Remember I'm not looking to put the most power, just a strong power-band (hitting full-boost by 4500 rpm) and about 400-450whp.
smokelessti
Jan 31, 2010 08:48 PM
