Inline Pro vs Laskey block?
Old Jun 27, 2011 | 06:54 AM
  #21
passmans2kny's Avatar
you are correct, but you can bore them out only to like .5 before u start hitting the frm
Old Jun 27, 2011 | 07:06 AM
  #22
wadzii's Avatar
Banned
FRM is not a coating, it is a material.. like steel or aluminum.
It's an aluminum carbon fiber composite.
The frm is 3mm thick so you in theory could bore it quite a bit, but Mahle will only produce 0.25mm oversize pistons since thats all honda makes and no one has done any testing on anything bigger. I plan on getting a set of 88 and 89mm pistons made soon to actually do some reliability testing at larger bores on the stock sleeves, but that would take a while to complete, so 0.25mm over is what we have now.
FRM is what makes the sleeve strong, it is stronger than the standard iron that honda uses in their other blocks (k-series and b-series). When boring over you dont "hit" frm, you are always in the FRM until you go THROUGH the frm and get to bare aluminum.
Old Jun 27, 2011 | 07:08 AM
  #23
Batbite's Avatar
Seems to me that if you're going to go through the trouble of tearing the engine apart to bore it out....that you would just add the sleeves and get rid of the FRM all together...otherwise why bother?
Old Jun 27, 2011 | 07:17 AM
  #24
wadzii's Avatar
Banned
IMHO unless you want to salvage a trashed block there is no reason to sleeve the block. Honda used FRM because its stronger than the normal steel sleeves they use in the k/b blocks and we all know the steel sleeves in the k blocks are very strong with a number of those guys making 7-800 hp for a very long time on stock sleeves.
Old Jun 27, 2011 | 07:37 AM
  #25
Sideways's Avatar
What is your source for FRM being stronger than steel (or iron)?
Old Jun 27, 2011 | 07:38 AM
  #26
B5254T4's Avatar
Really good info, thought the FRM were thin as coating and that´s why we had to sleeve every time the cylinder wall got damaged.
Good news actually, a cast factory sleeve will always seal better than pressed ones.
Old Jun 27, 2011 | 07:53 AM
  #27
wadzii's Avatar
Banned
There have been many articles and such released by honda stating this. Back when H22's were first released and again when f23's and the s2000. They went to FRM so they could increase bore size with out increasing bore spacing. they were not able to do this with normal steel sleeves because they were not strong enough. They went with FRM because it is much stronger and allows for longer life and larger bore sizes.
Old Jun 27, 2011 | 09:02 AM
  #28
oh guess i was wrong about hitting the frm, i learned something today, good info here
Old Jun 27, 2011 | 09:50 AM
  #29
wadzii's Avatar
Banned
lol, its cool.. there are ALOT of misconceptions out there as to what frm is and exactly how to work with it.
Old Jun 27, 2011 | 12:07 PM
  #30
twomodified4u's Avatar
I think either one is good for more than you need
