Inline Pro vs Laskey block?
Old Jun 27, 2011 | 12:18 PM
  #31
*JG*'s Avatar
Yeah my block is o-ringed passmans2k. when shes sealed, shes sealed. Hoping to not have to break her apart for a long time!
Old Jun 27, 2011 | 01:27 PM
  #32
passmans2kny's Avatar
redboost asked that jg, but good to know anyway
Old Jun 27, 2011 | 01:33 PM
  #33
B5254T4's Avatar
People will probably jump in here and say "I think either one is good for more than you need" a few more times but I never asked about the max power.
Would the IP block handle track driving as good as the open deck? Any problems with internal coolant leaks? Problems with compression leaks over time and stuff like that. More important info IMO.
Pretty much decided to go Mahle and stock block after this thread, a lot of stuff I didn´t know about this engine.
Any high numbers on this combo yet?
Old Jun 27, 2011 | 01:58 PM
  #34
make sure u go to a machine guy who knows how to bore those cylinders, its not your typical bore and hone, its a different process, im sure wadiz can chime in on that one
Old Jun 27, 2011 | 02:29 PM
  #35
*JG*'s Avatar
hahaha damn! you can tell its been a long day!
Old Jul 21, 2011 | 04:55 PM
  #36
miguel329's Avatar
I went laskey sleeve and.build on a b18c hit 500hp never stressed on block giving me issues.... Drove it like i stole it every day... Parted out hatch got s2 plan have laskey do my s2 engine. His customer service is great.
Old Jul 21, 2011 | 05:33 PM
  #37
Blucky87's Avatar
Benson sleeved and laskey built.. oem bored and 9:1 compression
Laskey did a great job and had quick responses. only have 1500 miles on her but compression checked good and runs strong so far.
Old Jul 22, 2011 | 06:44 AM
  #38
s2kadrenalin's Avatar
^ Same as me (I do believe - having bought this motor 2nd hand).
Only I'm not sure if I'm darton sleeved or Benson, the advert was a little confusing....
Originally Posted by Advert
CP PISTONS , Carrillo Rods , crank has beeen balanced and micropolished brand new OEM bearings the sleeves are darton and the block was put together by benson from laskey racing everything is Blueprinted the head studs a arp and was tourqued down to the right specs the head was port & polished, ferrea Stainless Steel valves, dual valve springs, titanium retainers, ect... stock cams as there is nothing better out the than the stock ones motor was built to make 700hp
Old Sep 20, 2011 | 06:35 PM
  #39
DFWs2k's Avatar
so if the block/cylinder walls are fine, is it acceptable to just get new mahle pistons and everything else needed to build the block, vs having it sleeved with the then necessary hardware?
Is there a power level when the sleeves are "needed" over the stock bore and mahle pistons?
Old Sep 20, 2011 | 06:52 PM
  #40
Corey Maurer's Avatar
Whats the price on a lackey build?
