Inlinepro diff kit axles won't tighten
Old Sep 30, 2011 | 12:21 PM
Spec_Ops2087's Avatar
Default Inlinepro diff kit axles won't tighten
I have the Inlinepro r200 diff, axle, and drive shaft conversion kit on my s2k. It seems recently my axle nuts keep loosening on both sides even though they are torqued to the proper spec. Anyone having this problem and if so have you found a solution? Should I just throw an air gun at them and knock it up to like 400 lbs?
Old Sep 30, 2011 | 12:27 PM
TerminatioN's Avatar
I didn't have anything that could measure as high as the "proper spec", so thats what I did. No idea what they're torqued to, but its definitely enough, lol. Seems to be working fine for me.
Old Sep 30, 2011 | 01:41 PM
It is a 20 something mm bolt, so I have to assume it can withstand a good amount of torque. I believe the helms manual calls for ~230lbs but that's obviously not working...
Old Sep 30, 2011 | 02:03 PM
Yep, my tuner and my friends and I came to the same conclusion. Like I said, seemed to stand up fine to the air gun and I haven't had any problems since.
Spoolin
Forced Induction For Sale
Nov 2, 2017 12:23 PM
staylor725
Apr 23, 2017 01:44 PM
btstone84
Apr 9, 2008 05:10 AM
