inlinepro fuel rail question
Old May 31, 2010 | 04:40 PM
ghettocrxsi's Avatar
Default inlinepro fuel rail question
What size is the injector bung supposed to be on this rail? Measuring thestock 07 rail vs this one its over an 1/8th or more difference.
I cannot put my id 1000's in, yet I can put them in with my stock rail... Its like 7/16 vs 9/16.
I am going to measure with a caliper tonight at work to verify im not crazy.
So what size are your guys rails?
I am trying to put my return fuel line on so I can go over 400whp.... And what a pain in the a** it is btw!
THanks
Old May 31, 2010 | 04:50 PM
mys2k3's Avatar
I have the ID 1000's and they did fit in the IP rail. It's tight but they do go in.
Old May 31, 2010 | 05:52 PM
Bryan720's Avatar
06+ is different
Old May 31, 2010 | 08:27 PM
It came with their 06+ returnless fuel line kit. I am adding their bolt on kit...
It will bolt onto the fuel rail stud but the injectors will not. I'm going to be calling them tomorrow.
Old May 31, 2010 | 08:52 PM
Spoolin's Avatar
You may have just gotten ahold of a rail that they missed seeing that the bore size for the injectors wasnt correct. I'm sure Ya will get it straightened out.
Old May 31, 2010 | 09:59 PM
Ok so stock is 13.17mm and the inline rail I have is 10.61mm
Old Jun 1, 2010 | 03:03 PM
So after talking to inline pro they designed this rail for 11mm injectors for some reason.. So now I have to call t1 and see if he has the adapters and pay to get them here asap...
They need to put this info on their website.. What a pain in my a.....
Old Jun 1, 2010 | 07:41 PM
Spoolin's Avatar
That sucks. I wonder why they did it that way? I would think they would offer it either way and ask which you want when you order or just leave it the same size as stock.
Old Jun 1, 2010 | 09:04 PM
I figured they would be the same as stock so I never even checked till I was going to finish the install.
It was too late to call tony at t1 so first thing in the am I am going to call him.
I want to get this fuel system primed and checked for leaks so I can check it off my list and move on to making the intercooler pipiing and little stuff.
Old Jun 2, 2010 | 06:10 AM
Irishflame27's Avatar
do all the rails come like that? or just the 06+ applications cause if i go to put my ID1000's into my rail and they dont fit, i will be pissed!
