Inlinepro owners! Vacuum lines?
Originally Posted by FurY,Jul 9 2007, 08:44 PM
So since I'm not running a boost controller, I just connect the vacuum line from the turbo to the bottom nipple on the wastegate, and leave the top nipple alone?
I guess my question is does anything need to be connected to the top nipple on the WG?
Running off the spring and a manual boost controller both use the bottom nipple.
Originally Posted by Spec_Ops2087,Jul 9 2007, 09:21 PM
The top nipple is only used if your using an ELECTRONIC boost controller.
Sorry guys for the million questions... where does the line off the blow off valve feed into?
Originally Posted by FurY,Jul 9 2007, 09:36 PM
Awesome, thanks!
Originally Posted by Spec_Ops2087,Jul 9 2007, 09:55 PM
A vacuum source of some kind. Some use the nipple off the turbo (if yours has it) and others will use one of the nipples steming off the intake manifold. It doesn't matter either way.
