Inlinepro owners! Vacuum lines?
Old Jul 9, 2007 | 05:00 PM
FurY's Avatar
Default Inlinepro owners! Vacuum lines?
fixed
Old Jul 9, 2007 | 05:32 PM
TJTURBO's Avatar
the vacuum line goes from the turbo to the nipple on the side of the wastegate not the top of the wastegate.
Old Jul 9, 2007 | 05:37 PM
FurY's Avatar
up
Old Jul 9, 2007 | 05:41 PM
Ty.'s Avatar
Ty.
If you want to run it off the wastegate, you run your vacuum source to the side port on your Tial. You leave the top port vented.
-Ty
Old Jul 9, 2007 | 05:44 PM
FurY's Avatar
thanks guys
Old Jul 9, 2007 | 06:21 PM
Spec_Ops2087's Avatar
Originally Posted by FurY,Jul 9 2007, 08:44 PM
So since I'm not running a boost controller, I just connect the vacuum line from the turbo to the bottom nipple on the wastegate, and leave the top nipple alone?
I guess my question is does anything need to be connected to the top nipple on the WG?
The top nipple is only used if your using an ELECTRONIC boost controller.
Running off the spring and a manual boost controller both use the bottom nipple.
Old Jul 9, 2007 | 06:36 PM
FurY's Avatar
Awesome, thanks!
Sorry guys for the million questions... where does the line off the blow off valve feed into?
Old Jul 9, 2007 | 06:55 PM
Originally Posted by FurY,Jul 9 2007, 09:36 PM
Awesome, thanks!
A vacuum source of some kind. Some use the nipple off the turbo (if yours has it) and others will use one of the nipples steming off the intake manifold. It doesn't matter either way.
Old Jul 10, 2007 | 09:15 AM
FurY's Avatar
You're the man, thank you sir
Old Jul 10, 2007 | 10:48 AM
ChefJ's Avatar
No.
