install plx wideband/narrow band
Old 07-14-2005, 12:35 PM
03spa's Avatar
Default install plx wideband/narrow band
I purchased a narrowband replacement that also has a wideband output. plx 400m
The question I have is how do I replace the stock o2 sensor, there are 4 wires, under the car: 2 grey, white and black.
The replacement o2 sensor has 1 grey wire for narrowband. 12v and ground.
My question is what wire/wires do I need to splice into the grey new o2 sensor to have everything working correctly? Also do I splice the wires under the car at the old o2 sensor, or do I run the new 02 sensor wires to the ECU (if so which wire am I splicing into the wire, or am I cutting in half and connecting to the ecu input)?
Has anyone had success with swapping this o2 sensor, or should I just get a bung welded on and keep the stock one alone?
thanks in advance.
Old 07-15-2005, 10:05 AM
S2000RAT's Avatar
Get a bung and weld it on. Don't mess with the stock o2 sen. You will get a CEL.
Old 07-16-2005, 10:08 AM
Salaska's Avatar
Check out this, i have wired my PLX the same way and it works perfect!
Click here
Old 08-02-2010, 03:31 PM
silex's Avatar
Sorry for bring this back from the dead, but I need to know which pin in C101/404 it needs to be. Is any BLK/YEL wire okay to tap for +ve?
My thread:
https://www.s2ki.com/forums/index.ph...&f=26&t=806886
crisskro
10-07-2013 01:24 AM
vadhert
04-26-2009 09:13 AM
LHP_Sailor1P
07-30-2006 03:36 PM
LHP_Sailor1P
South Florida
07-30-2006 03:35 PM
03spa
07-17-2005 02:18 PM
Quick Reply: install plx wideband/narrow band
