Installing 550 injectors before fmu and pump?
I am slowly installing my vortech kit. Can I install my 550 injectors before i put in the fmu, fuel pump and emanage?
What about the ik22 spark plugs?
There realy is no need for the FMU if you will be using an e-manage and 550's. The whole point of swapping to bigger injectors is to not have to rely on super high fuel pressure for fuel enrichment.
I wouldn't even bother with the FMU. I would add an adjustable fuel pressure regulator, you may find it neccesary to turn down the fuel pressure with the 550's.
Do not run the car into boost without the e-manage tuned. You can either have stock injectors with the FMU, or your 550's with the e-manage.
Use the boost cut function of the e-manage as your Map voltage clamp, no need to add the Vortech Map clamp (the little black box)
