Intake manifold with Hondata Gasket
Old Jul 20, 2006 | 08:28 AM
Sideways's Avatar
Originally Posted by Spoolin,Jul 20 2006, 06:45 AM
Thanks man; I would appreciate the picture if you can.
Did you have to re-bleed the system also or just re-route the hose and it's good to go.?
The amount of air introduced into the system should be insignificant and not require bleeding. (If you loose lots of fluid while doing this then you might need to bleed. ) After a few miles and a major cooldown check the fluid level in the radiator.
Old Jul 20, 2006 | 09:08 AM
Spoolin's Avatar
Sounds good, thanks Sideways.
Old Jul 20, 2006 | 09:14 AM
geists2k's Avatar
Doesn't the Hondata gasket itself block off the flow? I thought I read this somewhere...
Old Jul 20, 2006 | 09:26 AM
WindchaserS2K's Avatar
Any DIY
Old Jul 20, 2006 | 10:05 AM
John_Z's Avatar
The Hondata gasket is blocks off the coolant flow through the #1 intake runner bung. I drilled mine out to allow flow.
In this pic you can see the small coolant hose which attaches at the same point as the upper radiator hose. I did this mod when I had my intake mani and cyl head off so it was cake. I don't know how hard it would be to switch out the stock hose for a longer one with everything still on the car
Basically the coolant from the cyl head now bypasses the throttle body and IAC.
Old Jul 20, 2006 | 10:24 AM
Isn't this will do the exact same thing
https://www.s2ki.com/forums/index.php?showtopic=315015
Old Jul 20, 2006 | 10:29 AM
John_Z's Avatar
^Almost the same but in that link you are completely blocking off flow and you will still have hot coolant in the IAC valve.
Old Jul 20, 2006 | 10:33 AM
For the mod. you did It is going to be really hard to do with the intake mainfold on.
Old Jul 20, 2006 | 10:41 AM
John_Z's Avatar
I think it will be because you need to remove a small hose clamp. An easier way would be to just spilce in a section of hose where the stock one leaves off. I'm not 100% any of this has a measureable difference, but I like to tinker
Old Jul 20, 2006 | 11:40 AM
GDM S2K's Avatar
John mind sharing how u go the IAC to work with an aftermarket TB?
