Intake Temps
Old Jul 23, 2006 | 09:26 AM
gotswap's Avatar
Default Intake Temps
For those who are forced induction. What are your average readings for intake temp? I am very curious to know if I should re-route my intake to the turbo. I am seeing high 120's when idling for a bit, should I be worried?
Thanks,
Mike
Old Jul 23, 2006 | 10:31 AM
jbotstein1's Avatar
I am installing my AEM serial gauge in the next week or so, but up till now I haven't had any temp readings. I know I'm running hot, but I'll chime in once I get the gauge working. Our cars with turbos seem to run really hot from what I've heard.
Old Jul 23, 2006 | 10:43 AM
Slows2k's Avatar
It's not uncommon for IAT's on stock NA cars to be over 135.
Old Jul 23, 2006 | 11:09 AM
John_Z's Avatar
Mine varies from 90's to 122 on very hot days.
Old Jul 23, 2006 | 11:27 AM
xviper's Avatar
Idling is not a good indication of what your system can do (if you are intercooled). Mine typical runs about 50*C (122*F), but idling it will creep up quickly to 65*C or more. However, once under way and air gets moving through the intercooler, the temp comes down within a minute or 2.
Old Jul 23, 2006 | 03:06 PM
gotswap's Avatar
All good info. The only reason I was asking is my car started bucking going into boost so I changed the plugs to no avail. Come to find out I am running ~9.5:1 afr while in boost. No wonder there is so much soot on my back bumper.
Back on topic the intake temps were a bit alarming at idle but dropped considerable once underway. Just thought I would throw that in as a possible cause.
Old Jul 24, 2006 | 06:41 PM
modifry's Avatar
Honorary Member
I've seen 160
Old Jul 26, 2006 | 03:50 PM
gotswap's Avatar
[QUOTE=modifry,Jul 24 2006, 07:41 PM] I've seen 160
Old Jul 26, 2006 | 06:14 PM
CaptKirk's Avatar
Just the other day I saw the temp get up to 95 deg. Celsius if I remember correctly. But it was a hot and humid day and went down again when I started moving. Don't remember what it went down to when I went WOT on that day but I know it jumps down VERY quickily once i get on the throttle...
zeroptzero
Oct 1, 2012 04:26 PM
oxhouser
Apr 6, 2009 07:00 AM
NineBolts
Jan 30, 2009 01:11 PM
yiannakos
Apr 18, 2008 11:00 PM
