Invidia Single Versus Dual for FI
Old Dec 21, 2008 | 04:22 PM
DesertWanderer's Avatar
Default Invidia Single Versus Dual for FI
I have a 2007 S2000 with the KW High Boost Kit. Does anyone have an idea about performance differences between the Invidia single versus dual exhaust if I am running the factory catalytic converter?
Thanks for your input!
Old Dec 21, 2008 | 06:12 PM
ChefJ's Avatar
either way. High boost kit with mods generally puts down 380hp 240 tq.
Old Dec 22, 2008 | 02:52 PM
DarkWingS2K's Avatar
Very minimal difference between the two. The dual you will gain more TQ. And the single will net you more top end power. I would say about 4-5 hp over all . If you really want to get a gain from the exhaust look forward to spending at least $1200 for a good 70mm exhaust. I'm running the T1R V3 70mm. i picked up 12whp with testpipe.
Old Dec 22, 2008 | 04:41 PM
Spec_Ops2087's Avatar
I gained 15rwhp and 10 torque going from an invidia dual to a 3" single so take it for what its worth
Old Dec 23, 2008 | 06:43 AM
siadam's Avatar
With most turbo apps, you want a full 3" mandrel exhaust.
70mm is only 2.75.
Old Dec 23, 2008 | 06:56 AM
RichV's Avatar
^that's true, but that is not as important with a supercharged car. Bigger exhausts are much more important on a turbocharged car, and some people that responded above have big turbos, not superchargers. If I had a big SC setup I would not spend much money on a big exhaust unless you just want the look or sound. It will probably give you minimal gains, but very little.
Talk to Grandmasterkhan. He has a Hi boost KW kit and had a big exhaust on it, but sold it because it didn't give him much of a gain. He is running stock exhaust now.
Old Dec 23, 2008 | 08:49 AM
I have the Highboost kit. And the 70mm exhaust is going to be the best for your setup. Kraftwerks tested there car with a 70mm exhaust. If you are going turbo go 3inch or bigger depending on your power goals.
Old Dec 23, 2008 | 10:39 AM
siadam's Avatar
I should have clarified.
S/C cars like a little backpressure, turbo cars on the other hand like zero backpressure.
You guys are correct in saying a 70mm exhaust would be optimal for a s/c car, while a true 3" would better benefit a turbo car, of course this is depended on power levels as well.
Old Dec 23, 2008 | 10:55 AM
Thats not entirely correct, without backpressure our wastegate wouldn't work
Oly_S2k
Sep 23, 2009 05:52 PM
Ap2masta
Jul 15, 2008 01:38 PM
rolso
Feb 21, 2008 09:57 PM
attack666
Jan 28, 2008 09:04 PM
s2k jesus
May 27, 2007 03:21 PM
