Invidia Test Pipe
Old Mar 14, 2007 | 07:56 AM
Yels2000's Avatar
Default Invidia Test Pipe
Are they all the same. It's 2.25" ID. I have Comptech header and Cat-back not sure what size the ID is would like it to be all the same. Comptechs pipe doesn't have an O2 hole. and they don't give sizes except for the tips.
I know 60mm comes out to 2.36" but can't find any that say ID they all are OD?
I'm so Confuused any help would be nice.
Thanks
Old Mar 14, 2007 | 08:48 AM
TheCarGuy2021's Avatar
I think you should be fine with an Invidia TP.
P.S. You will like your Toyos.
P.S.P.S I like your setup! Very similar to mine, how do you like it?
Old Mar 14, 2007 | 09:18 AM
Yels2000's Avatar
Thanks,
I like it a lot but its just not running right. My plugs are shot and the A/f is all over the place. Not getting it RE-tuned until May 9th and want to add a couple things before I go, ordered the Krank vents, and now trying to decide which test pipe I should go for.
Are you running normal boost?
Old Mar 14, 2007 | 10:07 AM
Yes, normal boost. The test pipe made it run a little leaner than I would like, but I added some tension to the Vortech FMU. I'll be putting an AEM fuel pressure regulator on come springtime. The Invidia is a quality piece. What plugs are you running?
Old Mar 14, 2007 | 10:41 AM
Yels2000's Avatar
I think NGK's or something not 100% right now, I ordered the Invidia Now to just wait till May 9th
Old Mar 14, 2007 | 11:19 AM
I'm running NGK 7173. They are NOT OEM, you shouldn't use the OEM NGK plugs with a F/I application. Also you want to gap them smaller (somewhere around .032"-.035").
Old Mar 14, 2007 | 07:08 PM
gomarlins3's Avatar
Ditto with the Invidia TP.
mikey430
May 23, 2014 05:51 PM
Elvi s2k
Mar 21, 2011 05:43 AM
robrob
Dec 17, 2007 07:09 AM
xman03
Sep 16, 2006 08:25 PM
DrDre1443
Jan 27, 2006 10:45 AM
