Issue with Greddy kit
Old Aug 1, 2010 | 09:43 AM
icemans2k02's Avatar
Default Issue with Greddy kit
Well I got the Greddy kit on the s2000. It is the factory Greedy kit. I had the kit running on the car no problem whatsoever and had no issues. I went and got the intercooloer piping repainted and after assembly the blow off valve acts different. Questions are what does the s2000 at idle show as vacuum? Also to make sure at idle the BoV should be open correct? Thanks for any help
Update: pretty sure it's the Bov now. Is there any default setting? I have had to adjust it hard or soft. It seems to be functioning however, it isn't making the same fluttering noise prior.
Bobby
Old Aug 1, 2010 | 09:56 AM
ChefJ's Avatar
bov needs to open at idle. as there should be vacuum in the line. I believe I register -85, -90kpa at idle.
Old Aug 1, 2010 | 10:02 AM
Thanks for the quick response Chef. My problem is the BOV stays closed at idle. I have checked for vacuum leaks but to no avail couldnt find any. Any suggestions?
Old Aug 1, 2010 | 10:10 AM
and at idle I am holding about 18 on the vacuum
Old Aug 1, 2010 | 10:24 AM
ChefJ's Avatar
+ or - 18? you don't want any positive pressure at idle. Of course if the bov is closed then there may be some pressure there. I would throughly go through all or your intake mani vacuum lines, check for cracks and whatnot. Check the spring on the bov to make sure it has enough pressure to stay open. Go one by one to the ports and plug them with your finger to see if the bov stays closed or starts to open. I am not the most farmiliar with the greddy kit but it operates basically the same as any other turbo setup.
Old Aug 1, 2010 | 10:30 AM
AFs2k's Avatar
ummm, shouldn't the BOV be closed until you let off the pressure and then it'll open to relieve it and close back up...
Old Aug 1, 2010 | 10:41 AM
ChefJ's Avatar
no bov stays open until you are on the throttle, positive pressure.
while playing with your throttle under the hood you should audibly be able to hear the bov closing when you give it some gas and opening when you let off.
Old Aug 1, 2010 | 10:47 AM
AFs2k's Avatar
Not mine. I have a Greddy RS.
Mine stays closed until I let off the gas. It opens, relieves, then closes back...
Old Aug 1, 2010 | 10:50 AM
AFs2k's Avatar
Like this:[media]http://www.youtube.com/watch?v=y9iYbBJ8ZDQ [/media]
Old Aug 1, 2010 | 10:53 AM
Ok i have the rz BOV and as of right now it stays closed until throttle is applied then it opens
