Issue with Greddy kit
RZ and RS are the same, just different colors.
The setting that it comes with out of the box is the factory setting. It's not the best i.e. one size does not fit all. Just tighten it until you get compressor surge, then back it out a little at a time until it goes away.
Ok guys here is the update. Took the bov apart and checked the diaphragm and everything was good on it. Come to find out the adjustment bolt at the top of the bov was leaking. I applied some thread tape to it and my problem ceased. Thanks for all the help guys
The BOV will stay shut at idle unless you gave an very light spring in the bov. It takes a combination of boost pressure pushing the valve and vacume from the manifold livting the valve when the throttle is closed in a boost condition to open the valve. If it stayed open in the case of a mass airflow vehicle then the car would sputter and missfire.
