JayC's SOS Build
When I started my Stage 2 SOS build, I figured I would go all out and get a 3.8" pulley off the bat. Even with that set up on a J's header and test pipe I made 380whp on a dynojet. Right now with the above + 3.4" pulley and aftermarket exhaust I made 430whp uncorrected spinning to 8500 on a f22.
With a 4.2" pulley with the parts you mentioned, I would guess 350ish whp on a dynojet.
FINALLY!! It's here!
[attachment=40095:602975_10151846383410101_16200948 30_n.jpg]
[attachment=40096:971205_10151846383260101_93194344 8_n.jpg]
I sent back the 4.2" pulley for a 3.6" (12-13 lbs boost). And sent back my oil temp gauge for a boost gauge.
This kit should be installed on the 15th unless something comes up but until then thanks for looking!
I also got in on the group buy , cannot wait for my kit to arrive here in the uk!
I will be purchasing an SOS clutch within the next month. I know you guys are all saying to go high boost straight away, I did contemplate that but I decided to stick with the 4.2, I'm then going to upgrade to a 3.2 in a few months as at least that way I will have something to look forward too! If i go with the high boost straight away I have a feeling ill get bored quicker if that makes sense. I've gone for the 1000cc injectors so I guess once I upgrade at a later date all I will need is a re tune.
Will get a little build going once the kit arrives!
