JayC's SOS Build
Old Jun 28, 2013 | 06:35 PM
  #51
coolberg's Avatar
Question, why install the fuel pump? I have same setup with MY06 and I was told I didn't need a fuel pump. Jeff also tuned my car.
Old Jun 28, 2013 | 06:58 PM
  #52
d16tof22's Avatar
Why is the boost so low? On the Science of Speed web site it says the 3.6" pulley should be around 13psi on the NOVI 1200; which is about the boost I would expect for the power numbers you're getting. I've heard freeing up the exhaust could cause a slight decrease in boost, but 3 psi is a good bit. Was the belt slipping up top?
Fantastic nunbers by the way x
Coolberg - you don't need to upgrade the fuel pump with the standard pulley or the 4.2" pulley, but anything over it's a good idea; especially with ID1000s.
Old Jun 29, 2013 | 03:39 AM
  #53
donaldmejr's Avatar
I've been told any changes to the exhaust side will not change boost. Other then valve tuning.
A 4.2" pulley only netted me 7-8 psi with full exhaust mods.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Old Jun 29, 2013 | 04:30 AM
  #54
coolberg's Avatar
I have the 3.6 and only got 10 psi. I have been struggling to find an answer for over a year as to where the 3 psi went. Only differences in my setup from OP is I have stock cat. My exhaust is 70mm Invidia Q300 and stock fuel pump. Jeff told me last year after my tune that I can add a smaller pulley easily and there would be no need to add a fuel pump.
Old Jun 29, 2013 | 06:55 AM
  #55
JayC07's Avatar
I bought the larger fuel pump because I'm not done with the car yet...
Originally Posted by d16tof22
Why is the boost so low? On the Science of Speed web site it says the 3.6" pulley should be around 13psi on the NOVI 1200; which is about the boost I would expect for the power numbers you're getting. I've heard freeing up the exhaust could cause a slight decrease in boost, but 3 psi is a good bit. Was the belt slipping up top?Fantastic nunbers by the way xCoolberg - you don't need to upgrade the fuel pump with the standard pulley or the 4.2" pulley, but anything over it's a good idea; especially with ID1000s.
I'm totally not sure why it was so low. Could me not gapping my spark plugs have anything to do with it?
Old Jun 29, 2013 | 07:14 AM
  #56
coolberg's Avatar
Jeff gapped mine so I doubt it's that.
mo19249
Sep 23, 2013 10:37 AM
mo19249
Jun 29, 2013 09:34 AM
leo520
34
Aug 19, 2009 05:21 PM
