Just another ptuning build thread
I'll take it for a spin and listen for it later.
I did take some temp readings of the studs after a spirited drive. The outer studs only hit 250 degrees. The inner hit 600 degrees.
I'm going to try the high temp locktite on the outer studs and nuts.
Originally Posted by s2klariat' timestamp='1392039797' post='23007772
Have you experienced any "creaking" from the motor mount? I get some creaking noises when coming to a stop or hitting a bump. Im just putting around town to wear in the new clutch disk. I dont have the kit installed, only the mount.
Quick update. I've put about 200 miles on the kit so far. It's a blast to drive. I'm having a problem with the two outer manifold studs. When I mounted it originally it would not fit over those two outer studs. I had to drill the holes out a little bit to get them to fit. Even after drilling it was very tight we had to squeeze and push the manifold on. This is why I think the manifold studs are backing out. The pressure against the studs and the vibrations are causing it to back out ... that's my theory. I informed ptuning of the problem. They told me to take off the manifold and expand those holes more. I'm not looking forward to this but I'm starting today. Take a look at the picture you can see that the holes don't quite line up.
