Just bought a CTSC kit from a community owner
Hey guys I just bought my CTSC from another S2K owner. could'nt beat the price for what it was. I know i am missing the water pump kit and the belt, the pump is on the way from comptech and belt is in the trunk of the S... I know i am missing some small hardware stuff for sure (bolts, washers, crush washers, etc..). Here are the pics of what i have. Just looking for some guidence on what else i need to bolt this up.
What I have for small hardware
Bolts, washers/bushings, and watercooler support arm
14mm to -8 fitting
alternator bracket and belt tensioner bracket (guessing??)
CTSC w/AC stuff, FPR, air box, water lines, intake arm, and bypass valve
blower unit
FPR w/ line and banjo fitting
Crank pulley
14mm to -8 fitting
blower unit
Crank pulley
Originally Posted by nightcrawler7188,Mar 29 2008, 03:13 PM
i thought you said you got the coolant pump? it's not there...
It will be here monday... you guys sure i have it all, direction say that there is 3 bolts for the vtec solidnoid mounting block (I have 2) ? Also is banjo bolt already on the car for the FPR (directions say it is supplied
Originally Posted by nightcrawler7188,Mar 29 2008, 03:26 PM
blower has 4 bolts that hold it in place, i only see 3
-A blower mounting bolt
-Fuel rail adaptor
-crush washer
also looks shy of some vaccume hose also!!
