Just bought a CTSC kit from a community owner
Old Mar 29, 2008 | 04:03 PM
RISLAR's Avatar
Cool, i think thats about all you need happy install, ps its real easy, just make sure you get the FPR correcty set and you'll be sorted
Old Mar 30, 2008 | 04:45 AM
soon2beS2Kn's Avatar
so you guys are saying that im not missing any bolts other than the third blower mounting bolt? Just trying to get my ducks in a row before i install this next weekend. Thanks for everything so far guys!!
Old Mar 30, 2008 | 05:36 AM
TelosHedge's Avatar
i don't see the vtec solenoid mounting bolts. they are longer than the stock ones.
i also don't see the 3 bolts necessary to mount the bolt cover up to the vtec solenoid bracket.
you will need the line to run from the FMU back to the stock fuel line - which connects via a fitting since you won't be able to remove the stock line easily. i used a barb brass fitting. i was told this is safe because it is only a return and the pressure is not substancial.
the triangular piece for the FPR relocation is a must, along with new crush washers and a banjo bolt.
make sure the gasket is included for the solenoid bracket as well, i don't remember if you can use the stock one or not.
i see you have new spark plugs - can anyone chime in and tell me if this is absolutely necessary or not? i have a CTSC and i'm preparing to goto the dyno and i want everything in order before i actually get there...
if you have any other questions please IM me or shoot me a PM. i just did this install last week so it's still fresh in my mind
Feuerrader
Mar 16, 2017 09:56 PM
jordannn93
34
Nov 13, 2012 09:42 AM
AirWick219
31
Aug 23, 2010 12:50 PM
LS2TT
51
Jun 21, 2007 06:21 PM
freshs2k
May 5, 2007 08:17 AM
