K&N Filter for Comptech SC
Old Sep 16, 2003 | 11:28 PM
AusS2000's Avatar
Default K&N Filter for Comptech SC
I know I've heard of someone replacing the blue foam filter with a K&N. I looked into it today and the Comptech filter has a 5 1/2 inch opening. K&N do a 5 and a 6 inch that fit in the stock box (just). I bought the 6 and intend to glue some rubber strip (1/4" thick) around the inside.
What have others done?
Old Sep 17, 2003 | 03:14 AM
cdelena's Avatar
Be careful with the gluing idea.. that rubber strip will cause a lot of trouble if all or part gets ingested. Usually not recommended.
Old Sep 17, 2003 | 05:23 PM
AusS2000's Avatar
Anyone?
The rubber spacer will be a ring with an inner diameter of 5.5 inches and an outer diameter of 6 inches. It'll be well and truly glued before placement and will fit around the intake horns outer edge.
I'm pretty sure it will be OK, I'd just like to know what others have done.
Old Sep 17, 2003 | 06:04 PM
cdelena's Avatar
Most have just continued to use the Comptech filter which is a perfectly good washable foam filter.
Old Sep 18, 2003 | 04:04 PM
jerrypeterson's Avatar
If it ain't broke, why are you fixing it?
Old Sep 18, 2003 | 04:13 PM
AusS2000's Avatar
It broke!
Seriously, I can't believe a tinkerer like you would ask a question like that!
I'm not a big fan of oil soaked foam filters. They are messy, restrictive and deteriorate over time. A good K&N not only works better but is easier to maintain. That's just IMNSHO.
Old Sep 18, 2003 | 04:32 PM
[QUOTE]Originally posted by AusS2000
It broke!
Old Sep 18, 2003 | 04:35 PM
AusS2000's Avatar
I agree. But when I get dyno prints of 135Kw I guess I start clutching at straws. Sometimes my enthusiasm out steps my monetary sense.
That said, they did throw in a whole lotta K&N stickers!
Old Oct 12, 2003 | 12:04 AM
AusS2000's Avatar
Here goes:
Old Mar 29, 2009 | 05:58 PM
streetrage's Avatar
You can fit a K&N RF-1048 even though it has a 1/2" larger inner diameter. I McGyver'ed mine by adding a thick layer of black electrical tape to the tube that it clamps on to, so that the filter fits snug when you tighten the supplied clamp. If you like, you can cut the hole on the box so that the intake can fit inside with the black tape and all. Or you can just be lazy and slide the pipe in from the inside of the box. And voila! You have a K&N filter in your comptech box! The lid closes barely, but safely, by the way!
