Kai's Mega DIY Build Thread
Got the transmission in and running but it's making some nasty noises, I'm thinking the input shaft bearings are badly worn
Can't decide if I want to rebuild or just get another one..
Yea, assuming the bearings are the problem. I had the transmission apart during the build and I thought everything looked fine, but that's obviously not the case. At this point, I'm looking at about $190 for the new bearings and seals or 520 for another transmission from LKQ.
Regarding you viscous diff. Not sure if you're aware already, but you can shim the diff for more lock.
http://zilvia.net/f/showthread.php?t=200226
http://www.nissansilvia.com/forums/i...h#?1#?1#agtpwd
hth
hth
