Kai's Mega DIY Build Thread
Old Feb 26, 2014 | 10:37 AM
  #21
starrman's Avatar
Kai! Nice set up man!
Old Feb 26, 2014 | 02:01 PM
  #22
S2-Kai's Avatar
Thanks guys! Can't wait to get the 350z trans in this car and putting some miles on it!
Old Feb 26, 2014 | 02:21 PM
  #23
Geebs's Avatar
Hope those injectors work for you. I would have them tested, from some where else other than five 0, before you boost. I went through 4 sets of injectors before five 0 got their act together and sent me a grouping < 2% static and dynamic.
O ya, Im pumped about the 350z swaps! I can't wait to see them in action
Old Feb 26, 2014 | 07:12 PM
  #24
S2-Kai's Avatar
Which injectors did you get from five-0?
Old Feb 27, 2014 | 04:38 AM
  #25
Geebs's Avatar
They were/are the asphalt II series, part number 0426F1600. For all the trouble, if I were to do it all over again I would have saved myself the year of fighting with five 0 and bought ID injectors.
Old Feb 27, 2014 | 05:47 AM
  #26
S2-Kai's Avatar
Well that's not comforting at all... thanks for the heads up. I was planning to get their new "black ops" injectors a try, but I'm kind of hesitant now... Anyways, the injectors will be 1 of the last pieces I buy, since I want to put some miles on the trans and diff setup and also break in the clutch before installing the turbo parts. Not to mention I still need to extend the passenger harness, relocate the fuse box and battery, blah blah blah -_-
Old Feb 27, 2014 | 05:51 AM
  #27
Geebs's Avatar
Hehe similar builds except different orders. I choose to get the fuel system installed first and running so I know I can at least get the car moving. But agreed changing one variable at a time is the way to go.
Old Feb 28, 2014 | 07:59 AM
  #28
S2-Kai's Avatar
Alrite, here are some pix of the diff setup I put together. It's not 100% complete yet, I will be cutting the side brackets to only use 1 bolt/ side vs 2 to make room for the hall speed sensor I will be making. The input flange on the diff had to be re-drilled for the u-joint as well as the transmission output flange. The drive shaft I had made is from a guy who builds custom drive shafts on ebay. Once again, I was able to reuse the stock axles with this setup.
20140224_132525_zpse16612b1.jpg?t=1393552653
20140224_132544_zps5c432f87.jpg?t=1393552642
20140224_132551_zps73deae59.jpg?t=1393552634
20140224_162245_zps631c6220.jpg?t=1393552626
20140224_162257_zpsa402257e.jpg?t=1393552615
20140224_162308_zps8b58bc41.jpg?t=1393552607
Old Mar 11, 2014 | 05:56 AM
  #29
S2-Kai's Avatar
Hey everyone, just wanted to keep this thread going with a little update. Got to put in some work on the Z trans swap this past weekend. I cut the flange off both the Z and S trannies and got it all mocked up with the clutch set on the block. Will be getting the 2 housing pieces machined flat and welded hopefully in the next week. I also had to cut the input shaft down as the Z shaft had extra length that was not needed. As always, comments, concerns, or suggestions are welcome.
20140308_130911_zpsdced4d5a.jpg?t=1394505820
20140308_130902_zps71aa1f35.jpg?t=1394505841
20140310_202238_zpsa6b4ec3a.jpg?t=1394505797
Old Mar 11, 2014 | 08:15 AM
  #30
Redline S2K's Avatar
Nice fab skills
