Keeping it basic with S/C
Old Aug 24, 2008 | 03:05 AM
mikey k's Avatar
Back on topic
I have a 343WHP Comptech setup on stock clutch & diff - no problems at all.
Depends on your driving style I have a lot of mechnical sympathy so no launches or super fast gear changes.
Old Aug 24, 2008 | 03:07 PM
s2kfrog's Avatar
Originally Posted by mikey k,Aug 24 2008, 03:05 AM
Back on topic
I can be a very aggressive driver, which worries me with such a setup. No intention to do hard launches, but I will be doing some hard driving otherwise. I am the type of driver who is either on or off the gas. I switch between grandma mode and speed racer. Hopefully it will balance out haha. I am however, very anal about my cars and tend to go overboard with maintenance, etc.
With that in mind... What sort of issues/concerns might you anticipate, if any?
Old Aug 24, 2008 | 03:11 PM
Enthralled's Avatar
If you use an HKS Fcon you can run any FI kit on your car.
Old Aug 27, 2008 | 11:34 AM
s2kfrog's Avatar
I think what I will probably end up doing is just going with kraftwerks base kit. I really want to just keep things as simple as I can and not have to worry about a possible need for a new diff and the required clutch/flywheel upgrade that goes along with the high boost kit. The hard part about this is the fact that I could have an extra 40whp or so for the same price. I may do the base kit then swap out the pulley for the high boost pulley when my clutch eventually burns out.
Old Aug 27, 2008 | 11:58 AM
jwa4378's Avatar
I wouldn't be concerned about the effect of the header on SMOG if you are running a test pipe...
You can get a comptech reinforced OEM diff if you don't want to shell out all the $ for the r200 conversion... and you can get it in a few different ratios (to better fit the SC power delivery, I believe most people run 4.44 or higher).
John
Old Aug 27, 2008 | 02:24 PM
s2kfrog's Avatar
John
With a test pipe it would be a quick and easy swap to stock for smog; whereas, with the header I would have to remove rotex to get the header in and out....
Will definitely look into a comptech reinforced diff.... What are we looking at for labor hours on such a job?
Old Aug 27, 2008 | 06:45 PM
ArinX's Avatar
does the blower really need to come off for the header? looking into my engine bay it doesnt feel like it.
Was thinking of replacing my berk w/ a js or toda
Old Aug 31, 2008 | 08:15 AM
King_'s Avatar
is there a particular header that is suggested for the KW kit? and or is there viable gains for the extra money? or is the KW kit good the way it is?
Old Sep 1, 2008 | 04:49 PM
EternalLx's Avatar
I am pretty sure the blower will have to come out to get a header in.
Kingsta the kw reflash was made for stock header so with a aftermarket one gains should be very little..... I already had it in there so i just left it and plan to get more out of it when hondata releases K-pro for MY06+
josserman
Dec 29, 2013 04:52 AM
Ks320
Feb 20, 2009 10:24 PM
pitstops
Socal Swap Meet
Mar 23, 2008 10:55 AM
NFRs2000NYC
Jul 27, 2007 08:10 PM
Ex Con
May 17, 2002 08:39 AM
