The Kit I am purchasing
Old Oct 16, 2008 | 08:22 AM
UsmcSway's Avatar
Default The Kit I am purchasing
Well I finally got the cash and am buying a turbo kit for my car off a buddy. Here is what all it comes with.
The Inline Pro Kit
Precision 6176R Dual Ball Bearing
1000cc Injectors w/pigtails
3 Bar Map Sensor w/pigtails
Resistor bar for injectors
AEM EMS 1052 w/a fresh tune
AEM Wideband/Electric boost controller
Inline pro 3mm HG
Inline pro down pipe/test pipe
3in exhaust to an apexi n1
38mm Turbosmart WG
Turbosmart pro billet bov
What do you think? How much hp max do you think I can safely attain w a good tune, on the stock internals w 3mm hg. Does this sound like a good setup?
Old Oct 16, 2008 | 08:58 AM
CU Nick's Avatar
With that set-up, you should easily put down 450rwhp with a safe tune. That's not uncommon at all.
Old Oct 16, 2008 | 01:41 PM
learning03's Avatar
I hope you have a aftermarket high flow fuel pump as well.
Old Oct 16, 2008 | 03:56 PM
dibi's Avatar
is your buddy a member here?
Old Oct 16, 2008 | 04:29 PM
9kFever's Avatar
Dont trust the tune. Get it redone. You can use it as a base map.
Old Oct 16, 2008 | 07:27 PM
AndyFloyd's Avatar
so its ok to reuse the 3mm hg? I wouldnt personally....
Old Oct 16, 2008 | 07:50 PM
RacerXI's Avatar
I would definitely not reuse a headgasket.
Old Oct 16, 2008 | 09:07 PM
CourageOO7's Avatar
Good choice of setups! Should make great power reliably.
Old Oct 16, 2008 | 09:14 PM
Kirpich's Avatar
InlinePro log manifold?
8940rpm
Feb 20, 2010 06:39 AM
QuagmireS2k
31
Feb 14, 2009 03:38 PM
QuagmireS2k
18
Jan 29, 2009 10:52 AM
sbrodacz
Jun 25, 2008 08:48 PM
S2000Geo
Apr 24, 2008 10:34 AM
