Knock volts not reading in aem log
Old Apr 17, 2012 | 06:31 PM
o'malley_808's Avatar
Default Knock volts not reading in aem log
Was just studying my cal file and logs from my dyno tune and remember the tuner saying the knock was in check.
Then when I looked at the logs the knock wasnt even budging. Think the sensor may be bad?
I seem to remember that you have to set the log to record the knock#1 RAW to record knock?
Here is the aem log from my 600whp pull. Knock stuck to 0.0195v
Old Apr 17, 2012 | 07:30 PM
indi00's Avatar
Don't have AEM Pro software. Maybe they are similar? In the AEMtuner software for the EMS 2, knock is enabled in this tab.
Old Apr 17, 2012 | 07:47 PM
Yeah its completely different unfortunately. I'm pretty sure its because knock #1 Raw wasnt recorded but I just want to double check with those more familiar with it
Old Apr 19, 2012 | 06:39 PM
Nobody?
Old Apr 19, 2012 | 07:29 PM
starrman's Avatar
Yes you are correct, to log knock you need knock #1 raw.
Old Apr 19, 2012 | 07:40 PM
Alright thats what I thought.
So since knock#1 volts is a result of knock #1 raw - knock table is it possible to have my knock table settings to allow knock#1 read that consistant voltage all the way across or is my sensor toast?
Old Apr 20, 2012 | 06:37 AM
mase1's Avatar
which AEM ECU do you have? some of the old boxes, the knock sensor would be on number 2.
Old Apr 21, 2012 | 06:35 AM
It's a 1052 no wide band. My tuner changed the knock sensor cal values to something obscure so I didn't know of that would cause a consistant knock voltage like I am getting?
Old Apr 21, 2012 | 06:47 AM
s2knoob89's Avatar
Yea something isn't setup right. Knock volts should be increasing with RPMs
GaryRudolph
Mar 5, 2012 10:56 PM
HMFIC
15
Nov 2, 2010 10:17 AM
skool u
Jun 23, 2010 10:46 PM
Spoolin
Oct 3, 2005 05:35 AM
Hitman
Nov 4, 2004 02:52 PM
