knocking noise
i just noticed my car the other day under WOT at or around 6-8k that sometimes, i hear a noise like something is rolling around. sounds kinda funny to ask, but does this sound normal?
If you have always experienced this knocking/rolling around sound since the SC install, it could be normal.
If you have had no issues since the SC install, and this just showed up, out of the blue, then you might want to get it looked at. It could be any number of things causing this abnormal noise. Many untold inspections could and should be performed before the final cause is determined.
Good Luck!
Good Luck!
i just adjusted it again. and it doesn't sound like it.
it becomes audible at 4k rpm and up. it kind of sounds like a "vrrrrmmmvrrmmmmvvrrrrmmmmvvvrrrrrrmmm" when i let off the gas anytime after 4k as the engine wines down.
weekendwarrior44
Aug 12, 2017 10:51 PM
Moddiction
May 12, 2011 08:45 AM
