Replaced tct timing chain tensioner and hear a supercharger whine noise
Banned
Just popped in a ballade motorsports tct and now I'm hearing a whining noise that sounds like a supercharger, greaat. I read up a lot before doing this and did it exactly as it said to in the DIY write ups. I did not have to force in the tct by any means, it went straight in. I started it up and went for a drive to test it out and didn't hear anything until I was back in my neighborhood about maybe 7-10 minutes later when I noticed it. Wtf, should I just hope my engine doesn't blow up, or should I take it out and re-fit it? Or is this normal? Serious answers only please, thanks in advance to those who help.
Does it make the noise at idle? After I installed a new TCT, I noticed our cars ( ap1s only I believe) make a howling noise. The noise is louder with the airbox top removed. I just first noticed it after the tct install because I was a little nervous and was extra sensitive to any noise.
Banned
To me it sounds like a supercharger, I can't really hear it idling unless I give it gas. I can hear it when I'm driving and accelerating but only if I'm next to a wall until I get into higher rpm's because my car is loud. I'm fairly certain it was not there before
If its whining, the chain is overtightened plain and simple. And if you leave it like that it will destroy the engine, starting with the camwheel bushing. The chain should be whisper silent.
There can be no preload on the chain at all.
How many miles on your engine?
Did the TCT sit flush with the block, without holding it in?
Banned
Originally Posted by Billman250
If its whining, the chain is overtightened plain and simple. And if you leave it like that it will destroy the engine, starting with the camwheel bushing. The chain should be whisper silent. There can be no preload on the chain at all. How many miles on your engine? Did the TCT sit flush with the block, without holding it in?
Banned
Did the TCT sit flush with the block before you put the bolts in? It should sit there flush without holding it.
Also just making sure, I did say it isn't very loud at all just something I noticed after changing it out
