KraftWerks C38 Supercharger Kit FAQ Thread
Old Jun 12, 2017 | 07:45 AM
  #221
mmhm's Avatar
Originally Posted by s2000ellier
about 275, which seems 100 down from even the lower end. the stock exhaust wouldnt restrict it that much.
just did a comp check, 240 psi across all cylinders
id1000s, sos rewired walbro 255lp, 93 pump
80% humidity, 100F ambient, 115F IATs (sensor in manifold not charge pipe)
using NGK Iridium BKR8EIX
compression #4
compression #3
compression #2
compression #1
might be their dyno?
i ran 1 step colder plugs (ngk forgot part#), supplied grams pump & injectors, skunk2 4bar map sensor, oem header, 63.5tp & tomei exhaust for my tuning
final #'s (for track use) are 410hp/280tq @ hub (church)
Old Jun 12, 2017 | 09:20 AM
  #222
2.Slow's Avatar
Bought a used kit and in the middle of an install here. Stumped on the injector install as it seems all my parts are not here and the instructions are vague. Do the new 1000c gram injectors require fuel basket in the rail? For the assembly of the injector going into the manifold I have it adaptor ring (plastic), stock injector cushion then o-ring on the tip of the injector. Does this sounds right? Installed the injectors into the rail and manifold and seems nice and snug but I'm just not sure as I'm missing the other 4 pieces from the injector kit. Are the four pieces I'm missing just replacement for the stock injector cushion??
Old Jun 12, 2017 | 09:56 AM
  #223
s2000ellier's Avatar
anyone with a c38 willing to measure their inlet outlets to confirm numbers?
i'm seeing 76.xxx mm on the inlet OD and 63.xxx mm on the outlet OD
that makes it a c38 right?
Attached Thumbnails KraftWerks C38 Supercharger Kit FAQ Thread-61266188-92a8-4915-b6a2-045b3cc00407.jpg   KraftWerks C38 Supercharger Kit FAQ Thread-e6416ab9-f9f0-4032-8a93-9170e2cabb24.jpg
Old Jun 12, 2017 | 08:08 PM
  #224
beaudin223's Avatar
i will tomorow take some mesure for you
Old Jun 13, 2017 | 10:52 AM
  #225
can anyone tell me their timing adv at peak power? i am wondering if I am leaving power on the table by not having enough timing.
Old Jun 15, 2017 | 08:34 PM
  #226
beaudin223's Avatar
Old Jul 10, 2017 | 05:56 PM
  #227
2.Slow's Avatar
Just installed my V2 kraftwerks kit on my AP1 with AEM EMS, 1000c grams injectors and kit fuel pump. Bought the kit used from a local who claimed he pushed 420whp with an Evans tune. Just got mine tuned Friday with same bolt ons and same everything and only pushed 358whp at ~14.5 15psi , 93 octane on a "dynomite" hub style dyno. Do you guys think it could be the dyno reading so low? What the craps going on? Car drives and performs great just not the number I expected. I guess this tuner also did a kraftwerks Miata that had similar results not pushing expected listed hp.
Old Jul 15, 2017 | 11:07 PM
  #228
kumar75150's Avatar
put it on a dynojet if you're concerned about the number
Old Jul 26, 2017 | 07:53 PM
  #229
schhim's Avatar
Do you have any other supporting mods? Are your exhaust and headers stock? I'm making around the same at 380 with exhaust, header, AEM fuel rail, FPR and SOS throttlebody. I also have an AP1.
Old Jul 29, 2017 | 11:08 AM
  #230
Chibo's Avatar
This. Dyno is a tool, don't try to compare numbers straight across. Does the car feel good? Good.
