KraftWerks C38 Supercharger Kit FAQ Thread
Old Aug 16, 2018 | 09:25 AM
  #261
Boosted04S2K's Avatar
Originally Posted by outeiroj
Just wanted to respond to this as I’m sitting in a dinner waiting for a burger after leaving Evans... the SOS wiring did correct the fuel cut off issue. He did however encounter fueling issues above 7000rpm but he was able to correct it. He told me to keep an eye on the grams injectors as he’s already run into failures in a couple of s2000 causing severe lean issues on hot starts as well as fuel cut out at high rpm... and he reiterated to not run the grams pump rather the walbro which I had already installed prior due to bad reviews from grams pumps
and in case anyone’s curious 451hp 301ft/lbs
Is that a -91 or -92 blower? How many lbs of boost?
Old Aug 16, 2018 | 01:30 PM
  #262
outeiroj's Avatar
c38-91 and 14psi on pump gas (93 octane)
edit: btw, I saw the vid of your car being put together by LHT and it was the motivation behind me relocating the air filter to the same location as yours, props on how your car came out
Old Aug 16, 2018 | 08:18 PM
  #263
Kyle's Avatar
My plan is to go boosted come springtime, I'm glad I ordered the SOS wiring kit just for peace of mind. I've seen enough from all tuners that the grams pump is junk, but now that I'm hearing about the injectors being shit too I might get myself some ID 1050s and call it a day....I thought Grams were just rebranded bosch injectors? I wish KW would just offer the kit without the fueling, save me a few hundred bucks.
Old Aug 16, 2018 | 11:36 PM
  #264
outeiroj's Avatar
well according to Evans he’s seen 3 out of about 100 grams injectors with issues... he did recommend the id1050 if I swapped them out but he was pretty confident after the tune that my injectors were working fine...
we we were both pretty happy with how things turned out... with the exception of the fuel pump & the vtec solenoid bolts it was a 100% out of the box bolt on kit
Old Sep 27, 2018 | 01:37 AM
  #265
schhim's Avatar
I was troubleshooting a problem with my kit and I noticed one of the mounting bolts backed off from the supercharger. I took the bolt off and realized the bolt went straight through the supercharger! I'm not mechanical engineer but this doesn't seem right. Is anyone else's supercharger like this? I checked and all four mounting bolts went clean through into the supercharger.
the photo shows the hole with a light going through the supercharger.
Old Oct 10, 2018 | 05:20 PM
  #266
avlis's Avatar
Hi!
I would like to know what is the difference between an Ap1 kit and a 04-05 Ap2?
I bought a kit that comes from an Ap1 with the 30 mm upgrade and the pulley is a 90mm.
Did everything fit on my Ap2 without problems?
I wrote to Kraftwerks but I got no answer ....
Thank you!
Old Jan 13, 2019 | 06:30 AM
  #267
Code's Avatar
I just posted on another thread. I received my kit last week from KW (2006 S2000 with -81) It comes with black oxide ARP bolts now for the Vtec solenoid mounting and there is a 3rd mounting bracket in the package. if someone can help me post pictures I can text or email them. Does anyone know what the 3rd mounting bracket is for? It is "L" shaped with one open hole and one threaded hole.
Also, what are the torque specs for the QTY6 bolts that attached the KW crank pulley to the adapter? Red or blue thread locker for those 6?
Old Aug 16, 2019 | 07:46 AM
  #268
kdurning's Avatar
I just ordered mine, 38-92 \ 30mm. i know i should change the injectors and pump. Is there a list of the bolts that need to be replace with arp\grade 8 hardware? it will be tuned on a kpro v4, and is getting the 4 piston pro series head (already had it).
Old Aug 19, 2019 | 12:43 PM
  #269
FastUnicorn's Avatar
I have read a lot that the Kraftwerks kit sounds kind of like a vacuum cleaner. I was wondering, can you still hear the signature S2K induction noise? I put on a K&N intake mostly just to get the best noise possible, but I have a stock exhaust (HFC) because I don't like 4cyl exhaust noise. Every video I have found usually has a loud exhaust that drowns out the intake noise. Can you still hear VTEC engagement, etc?
Old Aug 19, 2019 | 07:40 PM
  #270
outeiroj's Avatar
mine does not sound like a vacuum cleaner. it does have a constant suction noise but would not describe it anywhere near the sound of a vacuum and I personally loves the way it sounds
