Kraftwerks SC w/ Infinity calibration file
Old Oct 30, 2015 | 10:51 AM
schhim's Avatar
Default Kraftwerks SC w/ Infinity calibration file
Hey everyone. I'm making a request for someone's calibration file on the AEM Infinity with the KW kit. Please let me know if you have anything different than what was provided on the kit so I can change it in the engine set up. This is just to allow me to drive the car to a tuner or on a trailer to get it properly tuned. Thanks.
Old Oct 31, 2015 | 10:01 AM
beechx1's Avatar
Does KW have one? If so, why not use it?
Old Oct 31, 2015 | 05:19 PM
schhim's Avatar
No, I asked. They only have a base tune for the AEM V2. Unless I'm mistaken, the calibration files aren't compatible.
Old Oct 31, 2015 | 08:03 PM
Habitforming's Avatar
Time to get a trailer with a winch...
Old Nov 1, 2015 | 11:51 AM
beechx1's Avatar
Do you have a stock calibration? If so, put the OEM injectors back in and drive it carefully to avoid the MAP going above atmospheric. Limit lower rpm and acceleration rates of an econobox. Or take the belt off to ensure that you don't get high MAP. Or remove the BOV so that the blower can't produce high MAP.
The key with the stock calibration is to use the OEM injectors and don't let the pressure downstream of the throttle plate get above atmospheric.
This kit really makes the car a whole different car. It still drives and handles just as well as it did before. But the power is simply amazing.
Old Nov 1, 2015 | 02:14 PM
schhim's Avatar
Beechx1, thanks for the advice. Using the stock injectors might be the best route, that and possibly renting a trailer. Thanks!
sarge1
Apr 1, 2011 07:49 AM
slicko9
Nov 2, 2010 06:22 AM
Slomo Corey
24
Nov 4, 2007 06:20 PM
