Krank Vent Update
Old Jan 11, 2007 | 11:07 AM
kane.s2k's Avatar
Default Krank Vent Update
Please see this thread for the brief update on the product that I sell for future customers:
https://www.s2ki.com/forums/index.ph...T&f=1&t=452783
Old Jan 12, 2007 | 04:55 PM
NFRs2000NYC's Avatar
Update, schmupdate...
The best damn mod I put in my car....made an even bigger difference on Dave's turbo RSX. Car stopped burning oil (the plumes from the exhaust at idle looked like a small forest fire).....cant say more good things about it....Car definetely pulls better, and it does feel like power is being robbed.
Buy it!
Old May 14, 2007 | 12:15 PM
foxer10's Avatar
What's it mean when you have the krank vents on and dip stick still pops out?
Robert
Old May 14, 2007 | 12:20 PM
my01s2k's Avatar
trying to buy one, but every time I click on the link, it would say product not found. do you still have them in stock or completely sold out?
Old May 14, 2007 | 12:24 PM
Venomous S's Avatar
Robert
You have both installed?
Your system is not sealed somewhere. Maybe they were installed incorrectly?
When I pop my dipsitck out or remove the oil cap, I hear air being released from the crankcase which tells me they are working as far as I can tell.
Old May 14, 2007 | 12:41 PM
foxer10's Avatar
Yes, both installed facing away from the motor.
So small vent is inline with the pcv hose going into the manifold. And the larger vent is on the front nipple venting to atmosphere with a k&n filter on the end.
Im getting -22in/hg at idle.......it sucks good when you pull the dip stick out,........ at around 5-6k rpm, you can hear air coming out of the front vent (like a whistle sound) and around 7-9k rpm, the dip stick pops out.
Robert
Old May 14, 2007 | 05:17 PM
Aze85's Avatar
here is a pic of the KV, hope this helps ur problem
Click pic for bigger view
Old May 14, 2007 | 06:25 PM
foxer10's Avatar
yep its installed like that... any ideas? way too much blow by? But the krank vent is supposed to help seal the piston rings for less blow by... !??
Old May 14, 2007 | 08:08 PM
GoFaassttt's Avatar
Couple of suggestions:
Check the valve between the PCV and intake manifold to make sure the valve has not failed. Mine failed and caused my dipstick to pop and spray oil due to the excess pressure.
Also check the valves to make sure the arrows are pointing in the right direction ... could of been labeled wrong.
Old May 15, 2007 | 05:16 AM
foxer10's Avatar
ill check the valves for damage...... but theyre all flowing correctly as i blow into them after clamping them on the hoses to verify.
THX
seansniper
Aug 19, 2012 07:02 PM
apxking
Oct 18, 2009 01:35 AM
IwantaS2000
Nov 3, 2006 06:57 AM
white03_s2k
Apr 20, 2006 08:50 AM
s2kdriver80
Feb 1, 2005 06:33 AM
