Krank Vent Update
Please see this thread for the brief update on the product that I sell for future customers:
https://www.s2ki.com/forums/index.ph...T&f=1&t=452783
Update, schmupdate...
The best damn mod I put in my car....made an even bigger difference on Dave's turbo RSX. Car stopped burning oil (the plumes from the exhaust at idle looked like a small forest fire).....cant say more good things about it....Car definetely pulls better, and it does feel like power is being robbed.
Buy it!
Buy it!
Originally Posted by foxer10,May 14 2007, 03:15 PM
What's it mean when you have the krank vents on and dip stick still pops out?
Robert
Robert
Your system is not sealed somewhere. Maybe they were installed incorrectly?
When I pop my dipsitck out or remove the oil cap, I hear air being released from the crankcase which tells me they are working as far as I can tell.
Yes, both installed facing away from the motor.
So small vent is inline with the pcv hose going into the manifold. And the larger vent is on the front nipple venting to atmosphere with a k&n filter on the end.
Im getting -22in/hg at idle.......it sucks good when you pull the dip stick out,........ at around 5-6k rpm, you can hear air coming out of the front vent (like a whistle sound) and around 7-9k rpm, the dip stick pops out.
Robert
Robert
Couple of suggestions:
Check the valve between the PCV and intake manifold to make sure the valve has not failed. Mine failed and caused my dipstick to pop and spray oil due to the excess pressure.
Also check the valves to make sure the arrows are pointing in the right direction ... could of been labeled wrong.
IwantaS2000
Nov 3, 2006 06:57 AM
