KW Pulley bolts snapped
Old Nov 11, 2015 | 10:27 PM
Bran916's Avatar
Default KW Pulley bolts snapped
Anyone out there with this problem & have you found a solution?!
Old Nov 11, 2015 | 11:33 PM
braeden's Avatar
Nasty
Old Nov 12, 2015 | 05:10 AM
Habitforming's Avatar
Well that's new, and no I don't think anyone else has had this problem (or at least, no one has reported it on here).
Contact KW, they'll get you straightened out. I don't think this is an issue you'll see again, provided everything is put together correctly.
Did you install the kit, or did a shop? If you did, did you torque things properly? If a shop, are they trustworthy that they torqued things properly?
Old Nov 12, 2015 | 07:46 AM
vader1's Avatar
6 bolts snapped like that? Did the compressor seize or something?
Old Nov 12, 2015 | 09:07 AM
killerbee_vr6's Avatar
Habitforming still defending the indefensible
Yeah, but, John, if The Pirates of the Caribbean breaks down, the pirates don't eat the tourists. ...
Old Nov 12, 2015 | 10:13 AM
s.hasan546's Avatar
sorry to hear. surprised to see all 6 snap. I think a lot of the bolts in this kit need to be upgraded. I already have titanium bolts w/ safety wire for the vtec solenoid
Old Nov 12, 2015 | 10:19 AM
s2000Junky's Avatar
No belt slip = things eventually stressed and breaking.
Ever wonder why none of the main & accessory belts are cogged on your engine from the factory?
Old Nov 12, 2015 | 10:55 AM
skinsfn36's Avatar
Damn, that must have been some serious force on it.
I'm starting to think there is/was a serious quality breakdown for whoever Kraftwerks uses as their fastener supplier.
Old Nov 12, 2015 | 11:05 AM
Memo6453's Avatar
thats new... geez... sorry to hear this. Did this happen under very hard load? thats crazy...
Old Nov 12, 2015 | 01:51 PM
Bran916's Avatar
I saw one other person had the bolts snapped but his hub adapter bolt also snapped as well. My hub is fine, i believed it might be because the belt was too tight? I installed it correctly with the correct torque specs. It all happened while driving
