KW Pulley bolts snapped
Prior broken pulley bolts were the center bolt that goes into the blower directly. This was isolated by KW to a limited set of blowers due to a probable installation error of the hub by KW. Only one person had a recurring issue here, and he is in Argentina and wasn't sending the blower back for repair, which is a likely component of his repeated failures.
Broken VTEC solenoid bolts were isolated to installs that weren't properly & evenly torqued. Everyone that had broken bolts stopped having the problem after using a torque wrench to evenly tighten them. Also worth noting other kits in the past have had failures here.
This issue has never been seen before, with the 6 pulley to hub bolts breaking. OP acknowledges there could be an issue with too tight belt tension, and also never replied about them having been torqued & loc-tited properly.
Are there any other repeat failures out there that don't fall into one of the above? All this talk about how the mounts aren't sufficient etc etc yet I just don't see the evidence for it. My 5k miles, LBPS2k's 6k+ miles, and one of LHT Performance's customers who is approaching 20k miles (including track duty) are pretty good indicators the kit can be reliable if installed properly.
It is a bad design, especially for the s2k's motor due to its high reving nature. The primary gear reduction of centrifugal supercharges are extremely high, imagine 10 to 1. That means when you rev your motor from 1000 to 9000 rpm in 2 seconds, the super charger has to rev from 10,000 to 90,000 rpm in the same time frame. This puts an extreme amount for stress on the components since the belt is cogged and can not slip. That is exactly the reason most centrifugal superchargers do not use cogged belts. When the belt slips it is actually protecting the components including the primary reduction gears/ pulleys, ect.
I guarentee that a lot of these problems are from belts being too tight also .. Mine is really loose compared to serp belt .. Haven't had a problem in a while thank god and had some good track days .. If the clogged belt is a problem..i also have not hit red line .. They should give us new pulleys and regular belts .. They put a cogged belt and the only reason I can understand is to stop slipping .. But every one says the slipping is good .. So why .. I want kw to do a test and just redline the piss out of a s2k with their kit and see what happens ..
I hate to say this, but stay tuned for the next related cogged belt failure...
Originally Posted by Habitforming
FWIW I've bounced off of my "soft" AEM rev limiter dozens to hundreds of times by now. I don't do it intentionally, but it does happen sometimes. I stopped puckering over it months ago.
