Leak
Old Feb 20, 2014 | 10:15 AM
mirabileboy's Avatar
Default Leak
Old Feb 20, 2014 | 10:17 AM
passmans2kny's Avatar
cant see the pic at work but if theres a crack in ur manifold, I would be concerned and fix that immediately
Old Feb 20, 2014 | 10:31 AM
s2klariat's Avatar
Hard to really see if it's just a surface crack or if it's through. Good way to see if it is leaking is to hold a small piece of thread over it while the engine is running and see if it blows around at all. If that is a crack, it wouldnt be big enough to verify by sound, but may be big enough to still leak.
Old Feb 20, 2014 | 10:34 AM
1SlowSi's Avatar
I wouldnt worry about it unless your AF start changing, exhaust leak sounds, and/or loss of power. You'll know when its a big enough crack to cause issues.
Old Feb 20, 2014 | 12:58 PM
waleed786's Avatar
The crack would suck in oxygen, making the wideband think that its running leaner that it really is
Sent from my HTC One using Tapatalk
Old Feb 21, 2014 | 07:00 AM
Skeero's Avatar
Do you have a local community college that offers welding? Take it there and they'll weld it for free. Make sure they weld it all the way, because once the heat hits it it more than likely will keep cracking. Depending on their setup, you might not even have to take it off the car.
Old Mar 3, 2014 | 01:20 PM
cujet's Avatar
Take some better pics of the cracks so we can see them. The previous pics did not clearly show the cracks. Might help to point them out too. How many miles/years on the manifold?
Thanks
Old Mar 3, 2014 | 04:31 PM
StocS2k's Avatar
go elt or side
Old Mar 4, 2014 | 03:23 AM
illestrolla's Avatar
Changing to an ELT will require a ton of work. Pretty much re doing the entire turbo setup.
CBR2000
Sep 12, 2011 03:26 PM
boyguan
Apr 25, 2009 07:03 PM
8kGoodENuff
May 3, 2007 05:26 AM
jdmdohcpower
Nov 15, 2005 10:25 PM
