Lets talk fuel systems!
Old Jul 17, 2014 | 07:19 AM
Prokaw875's Avatar
Originally Posted by redboost10
which weldon fpr do you have?
I am actually planning on buying the regulator this week. I have everything besides the regulator and rail. What weldon do you suggest? I was planning on getting the standard A2040-281-A-120 P/N one for $250 list
http://www.weldonracing.com/product/...Regulator.html
Old Jul 17, 2014 | 07:21 AM
Prokaw875's Avatar
thank you hybrdthry911 for posting that stuff! signnnn... why do I feel like I am going to be buying ID2000`s soon and just being done with it lol.
Old Jul 17, 2014 | 07:23 AM
Prokaw875's Avatar
Originally Posted by lude92_si
Originally Posted by hybrdthry911
1000cc + 100psi base pressure will be cutting it too close to make 700whp on e85. I won't say it's not possible, but definitely not recommended. In addition the 100psi base pressure compounds your problems pushing the rail pressure up to about 130psi at 700whp. As you can see the Upper E85 Mark off the chart to the right. Does that make you feel comfortable?
What you may expect using 1300cc injectors at 75psi base pressure which would put the injectors at roughly 90% duty cycle.
And finally the spacious 2000cc injectors at 43.5psi base pressure.
So do I just went with id1300 and a walbro 450 E85 pump do you think I can push 600 on e85 by turning my fuel pressure up?
Correct me if I am wrong buy I was under the assumption that the walbro intank pumps dont like operating at high fuel pressures like the bosch 044 and larger pumps do. I think you can reach your goal regardless of 600 on E85.
Old Jul 17, 2014 | 07:45 AM
hybrdthry911's Avatar
600whp is a big difference from 700whp when it comes to fuel system. The reason is you need more fuel, and you are pushing more boost. Pictured below are your fuel demands, and a few pump setups. As you can see even with 45psi base + 25psi of boost to get 600whp, you are close to the limits, def make sure you are using lean protection, and fuel pressure protection if possible. The new Walbro E85 pumps are great but you can see at high pressures the 044 is still king.
Old Jul 17, 2014 | 01:03 PM
Prokaw875's Avatar
Im just reading and reviewing over the charts you posted here. Can you please inform me what the X and what the + represent on each chart? The lb/hr on the Y axis of the chart more or less is the injector size correct? and the X axis is obviously the fuel pressure. And the lines show how the fuel pump will perform depending on the pressure and how much it will pump?
Old Jul 17, 2014 | 02:13 PM
lude92_si's Avatar
Hmm just got off the phone with a big shop that works on lots of s2ks. Telling me with stock fuel lines and a 450 pump 500whp would be Max on e85.....hmm I been told I could make close to 600...anyone have big numbers with a single pump?
Old Jul 17, 2014 | 02:31 PM
Jin_SK's Avatar
I'm making 495 on a single AEM 320 with E85, I'd think a 450 would work with the right injectors.
Old Jul 17, 2014 | 02:59 PM
lude92_si's Avatar
Id1300 and up the pressure was the plan.
Old Jul 17, 2014 | 03:44 PM
bobbyrandolph440's Avatar
There is some on here that made 630s on stock lines 450pump, 1300s and on e85 I'll try to find the post it was about a year back
Sent from my VS870 4G using Tapatalk 2
Old Jul 17, 2014 | 03:47 PM
Sorry I was off he was on 2200s and made 690 https://www.s2ki.com/s2000/index.php...-walbro-400lph
