Lets talk traction....
Forced Induction foruma lot of guys are making well over 500whp these days and I'm keen to see what your doing to get your power to the ground..
Out of curiosity, is anyone running a stand alone Traction Control unit?
Maybe we could get some sort of break down chart happening? See if we can help out a few other guys who might be experiencing problems in this area.
Your thoughts?
For example...
Your S2K TQ / WHP:
Rear Wheel Size:
Rear Wheel Width:
Rear Tyre Type:
Rear Wheel Tyre Profile:
Rear Diff Mods:
Your thoughts?
For example...
Your S2K TQ / WHP:
Rear Wheel Size:
Rear Wheel Width:
Rear Tyre Type:
Rear Diff Mods:
I'm not making enough power to have problems beyond 2nd gear as far as the dry goes. My 295/17 Xtreme summers doing pretty good at a -3 camber road track set up. Any less tire contact patch would be dangerous at this level. I suppose much more power and I might have to look at some Hoosers R comp in this size, or just not get much of it to the ground before 3rd gear.
What are you running for tires?
Originally Posted by s2000Junky,Nov 12 2010, 10:29 PM
I'm not making enough power to have problems beyond 2nd gear as far as the dry goes. I recently bumped the car up to 10.5psi/380ish whp though and my 295/17 Xtreme summers are still doing pretty good. Anything less would be dangerous. I suppose much more power and I might have to look at some Hoosers R comp in this size, or just not get much of it to the ground before 3rd gear.
Your S2K WHP: 549
Rear Wheel Size: 16" (stock AP1)
Rear Wheel Width: 7.5" (stock AP1)
Rear Tyre Type: Mickey Thompson ET Street Drag radial 26 inch tall and 10.5 inch wide
Rear Wheel Tyre Profile: ?
Rear Diff Mods: None
I get slight wheel spin on colder nights, but holds up very nice. They dont do well in rain.
Originally Posted by DFWs2k,Nov 12 2010, 08:36 PM
I didn't really have dry traction problems w 245 re050s in the rear, sounds like yours aren't really that good...
Rim width 11.5"
Tire profile 295/35/17
180 Xtreme summer compound
Stock diff
Your S2K WHP:
Rear Wheel Size:
Rear Wheel Width:
Rear Tyre Type:
Rear Diff Mods:
550HP, (I think torque is more important for tire spinning, thats should be added (415 ftlbs of Trq)
17x9 +44 -3 Camber
Work Emotion CR Kai
Brisdgestone Potenza RE-01R (255/40 R-17)
No diff mods
I spin at 80mph.................its just too colde out now
Rear Wheel Size:
Rear Wheel Width:
Rear Tyre Type:
Rear Diff Mods:
17x9 +44 -3 Camber
Work Emotion CR Kai
No diff mods
Your S2K WHP: 491 hp 340 tq
Rear Wheel Size: 18 x 9 +51
Rear Wheel Width: Fit like stock, fenders rolled
Rear Tyre Type
unlop Direzza Star Specs
Rear Wheel Tyre Profile: 275/35/18
Rear Diff Mods: Puddymod Stage 3 diff., AP2 transmission
The biggest thing I use is my KPro boost by gear. I limit boost in 1st, 2nd and 3rd gears. I progressively increase boost through these 3 gears before turning it loose in 4th. This keeps me from spinning. The Star Specs are excellent tires. They really grip.
Rear Tyre Type
unlop Direzza Star SpecsRear Wheel Tyre Profile: 275/35/18
[QUOTE=JoeyBalls,Nov 12 2010, 08:47 PM]Your S2K WHP:
Rear Wheel Size:
Rear Wheel Width:
Rear Tyre Type:
Rear Diff Mods:
17x9 +44
Rear Wheel Size:
Rear Wheel Width:
Rear Tyre Type:
Rear Diff Mods:
17x9 +44
stickier tires are better then wider tires , and closer to stock camber is better too.
your best friend will be boost by gear on a turbo car, and lowering the gain so that the boost spools a bit slower.
i had 265 azenis 615s and spun 2nd gear from a stab with 344/245. i went to a 275 toyo ra1 r comp, i can floor first now
ask yourself, if the car isnt a daily, and doesnt see rain too much, then just put a sick tire on it
