line locker
Old Jun 5, 2014 | 06:57 AM
mixwell's Avatar
Default line locker
http://www.summitracing.com/parts/huu-1745000
anyone familiar with these?
Old Jun 5, 2014 | 07:19 PM
blixhavn's Avatar
front brakes from master cyl go in
comes out to front brakes
basically you push down on your brake pedal
push the button to activate the solenoid (switch works too, i prefer a momentary button on the steering wheel)
release the brake pedal... pressure stays in the front and releases the rears
and then you just sit and burn rubber with a smile on your face
however if you want to use this with abs still installed you will require 2 inline between the abs module and each front brake line. Pretty simple to hook up
hope that answers your question
Old Jun 5, 2014 | 07:47 PM
redboost10's Avatar
best thing on a rwd stick car
Old Jun 5, 2014 | 09:39 PM
Forcedbird's Avatar
Would this work with the engine off? (Used as a parking brake)
Old Jun 6, 2014 | 03:18 AM
mixwell's Avatar
oh good. guess i need to figure out the fittings since my co-worker is selling this kit off of his hot rod (domestic).
Old Jun 6, 2014 | 03:22 AM
mixwell's Avatar
its electronic, so it depends on how you hook it up.
but what if your battery dies?
Old Jun 6, 2014 | 07:03 AM
Forcedbird's Avatar
Well if the battery dies, does the line locker just stay in the closed position?
The reason why I am asking is because I want to install a BBK (All around) on my car.......but I also want a functional parking brake. I would like to go with Stop Tech but the parking brake will not be functional. That leaves me with only one choice, which is Wilwood. If this line locker can work as a parking brake then I will go with Stop Tech.
Old Jun 6, 2014 | 07:07 AM
baZurk's Avatar
This would make for a very effective parking brake hahaha
Old Jun 6, 2014 | 09:11 AM
Forcedbird's Avatar
I just did some research......not a good idea to use a line lock as a parking brake. Wilwood it is then!
Old Jun 7, 2014 | 10:11 AM
Phill24's Avatar
Deff not a good idea to use as a parking brake...but if u wanted to do it all u would need is a power source that stays on when the car is off
