line locker
Old Jun 7, 2014 | 10:33 AM
S2-Kai's Avatar
Originally Posted by Forcedbird
Originally Posted by mixwell' timestamp='1402053768' post='23192376
[quote name='Forcedbird' timestamp='1402033184' post='23192205']
Would this work with the engine off? (Used as a parking brake)
its electronic, so it depends on how you hook it up.
but what if your battery dies?
Well if the battery dies, does the line locker just stay in the closed position?
The reason why I am asking is because I want to install a BBK (All around) on my car.......but I also want a functional parking brake. I would like to go with Stop Tech but the parking brake will not be functional. That leaves me with only one choice, which is Wilwood. If this line locker can work as a parking brake then I will go with Stop Tech.
[/quote]
You definitely don't want the solenoid to be in the passive closed position and require power to release the brake pressure. Imagine cruising on the highway, not even going all that fast, when all of a sudden, you lose power to that solenoid and lock up your brakes. It's disaster waiting to happen.
Old Jun 7, 2014 | 05:25 PM
d-bo's Avatar
i have a staging brake as my E-Brake. using a CNC staging brake modified for my OEM ebrake handle if you want a BBK and want to remove the oem ebrake setup.
keep in mind i have an EVO.
my rear wilwoods use brake pressure to stop (obv lol)
you just run 2 new brake lines from the master, T into 1 to one side of the CNC brake, and then back out the CNC brake and T into the rear 2 calipers.
now i have a hydraulic ebrake instead of cable.
trackrabbit21
Aug 11, 2015 11:14 AM
124Spider
Apr 6, 2005 07:55 AM
quanfer
Oct 17, 2003 09:26 AM
Speedster
Apr 1, 2003 08:45 PM
Dragonx
Mar 22, 2001 07:43 AM
