Log Manifold on Engine Pic request
Old Jun 20, 2016 | 04:43 AM
S2K-OED's Avatar
Default Log Manifold on Engine Pic request
I'm looking to pickup a SOS oil filter adapter to avoid using a relocation kit. Problem is I don't know if it'll fit with my revhard manifold and GT3071R . SOS bottom mount manifold has the turbo a bit further back and at an angle (from what I can tell in their website's pics. So can anyone post a pic if they have one of the revhard or similar manifold with the turbo on it preferably a side pic where u can clearly see the distance between the turbo and where the oil filter mounts on to?
Old Jun 20, 2016 | 05:13 AM
TerminatioN's Avatar
Best I have, from my build thread awhile back. RevHard manifold and GT3076R.
Originally Posted by TerminatioN
If no one posts anything better by the time I get home I can probably go take a new pic for you.
Old Jun 22, 2016 | 05:27 AM
S2K-OED's Avatar
Thanks do you think the sos oil adapter would work with that setup?
Old Jun 22, 2016 | 08:11 AM
Jin_SK's Avatar
It might fit, but do you really want your turbo right next to your oil filter?
Old Jun 23, 2016 | 03:24 PM
MorngWoodStewie's Avatar
Judging from the top pic it's gonna be close judging from the bottom pic it looks like there won't be to bad of a problem, I'll try to snap a better pic of mine and upload to my photo bucket and reply again when I upload it so u can check it out I'll also try to get some dimensions for u seeing turbo size and manifold will most likely be off a lil be different. Btw it uses a nsx oil filter and if ur gonna run a oil cooler sandwich plate u need a 22mm one and not stock 20mm s2k one.
MB
Dec 5, 2015 10:31 AM
cuci591
Jan 23, 2013 04:27 PM
BB9KS2K
Jun 4, 2012 10:10 AM
blueap2
Dec 9, 2008 08:44 AM
CarbonS2000
Oct 2, 2008 06:33 PM
