the long awaited UPDATED cx racing turbo kit log/review!
Old Apr 24, 2019 | 05:20 PM
  #71
outeiroj's Avatar
Originally Posted by s2000ellier
checked base timing with my timing light and noticed the marks were rotating around the crank! guess the KW kit torn the rubber so I am waiting on a new oem crank pulley.
I wonder if anyone else with a KW kit has noticed or checked their crank pulley for failure
i replaced mine after initial install but prior to reinstalling the engine after inline pro rebuilt it. the stock oe crank pulley was still intact on removal but i replaced it after reading a thread on here regarding the rubber failing at higher age on their own anyways.
fyi... honda consolidated the different part numbers into one, so you may have to modify the kw adapter to fit with the new key orientation on the new oem pulley. its apparently a 50/50 shot.
Old Apr 30, 2019 | 11:21 AM
  #72
DrJimmyV's Avatar
Contacted them and they said it's interchangeable, as suspected. And ordered it.
What manifold studs did you go with? I bought some 38mm ARP's but feel 45mm may be more appropriate, as you mentioned 51mm was too long.
thanks for your insight!
PS: I drove down the guy who bought your old SSM once-f24'd track car.
Old May 1, 2019 | 11:24 AM
  #73
s2000ellier's Avatar
Yeah 51mm were too long for 2 spots, i ended up using a mix of the 51mm and the 45mm and even 1 oem one since i couldnt fit either the ARP ones
my advice is figure out which studs you can install on the manifold to turbine part, the bolts they supply suck to install, i should have done studs there but didnt think about it until it was too late. if i ever pull the turbo off i'll swap to studs.
Old May 2, 2019 | 07:14 AM
  #74
DrJimmyV's Avatar
Gotcha! Thanks for the heads up and information so far! I will probably use majority ARP 45s and if I have to use an OEM I will. I am using a T3 hotside T4 cold side hybrid turbo, so it's going to be fun making it all work together. My oil relocator pedestal seems like it is exactly where the hot side charge pipe goes so that will be fun finagling things to fit.
Hoping the downpipe clears everything since the turbo off the manifold will wind up being extended 1/2" or so, and still bolts to the rest of the exhaust... :|
Old May 6, 2019 | 01:59 PM
  #75
DrJimmyV's Avatar
I got this manifold in. It is about 17lbs. Messaged my fab guy regarding adding some welds over these...
"That's a China manifold
Ohhh realllyyy
Yes
That was welded once then they go back over it with high frequency pulse which give it that look
I dont kniw what any of that means
Know*
Lol. It's a horrible process
Really? Not strong?
It's not the greatest. It's not back purged the welds never really penetrate
I see
It's made to look like a good weld..its comparable to a shemale could fool you and might get a surprise later"
I called CXracing and asked them why the welds were incomplete, and they said that was just normal. See pics attached.
I am sending it back... -shrug-
Old May 15, 2019 | 01:52 PM
  #76
gotembro's Avatar
^^ keep up updated
Old May 16, 2019 | 04:49 PM
  #77
If I ever take mine off I'll look at mine. But the one I have doesn't leak and its wrapped so I don't mind how the welds look.
Old Nov 10, 2020 | 11:01 PM
  #78
S2KDAWG$'s Avatar
the long awaited UPDATED cx racing turbo kit log/review!-lnehdfz.jpg
Sup Dude, what size bolts and bolt thread sizing did you use to mount up the turbo to turbo manifold ?
Old Nov 14, 2020 | 04:49 AM
  #79
The ones they came with. If you find the size/thread buy studs instead of using their supplied ones as they suck to install.
burnindesirez01
Nov 19, 2005 02:18 PM
azndrunkyoon
Jun 14, 2004 02:45 PM
tboy911
Mar 16, 2003 07:39 PM
