Long overdue update CTSC 2006 411whp
Wait, my motor keeps popping up dipstick too. I know its a sign of bad piston rings, but compression test came out perfect. And when i put my hand above it with the dipstick out, theres quite a bit of air coming out...i think this is perfectly normal??
I was popping a dipstick for a long time and kept putting a bandaid on it. Could just be your o rings on the stick. Clean em. Or replace em. Run the dipstick around. Do a leak down. If your compression and lead down test come out fine you ok. I did a leak down and had 35% cylinder 3 whereas other cylinders were <5%
